SOLVED Boonar Dawner Prince
Haz
Hi!
I have this pedal with an issue of dropping voltage. Is has multiple voltages inside, 3v, 9, 27 volts. 2 boards interconnected. When I separate the boards, lower one with powersupply holds voltage ok leds on bottom board are working.
When I connect upper board, voltage drops in 1-2 sec and pedal turns off so I think issue is in the top board with FV - 1 chips.
I check every cap is tests ok with LCR meter, no shorted resistors. Nothing get's hot on IR camera. FV-1 chips heat up equally.
I have a minor delay effect when pedal is on untill it shuts off.
Here are the guts
Any ideas?
Any input is appreciated
Sounds like it might potentially be a voltage regulator problem
Possibly shutting down automatically
Did you check the power circuit for components heating up or just the FV1 board
Voltage doesn't drop on lower board even if both boards are connected.
I get 50C degrees on LF33, It's outputting steady 3.3V so I guess it is normal operation. Otherwise no hot components.
This looks way more complicated than I thought it would be. What do all these circuits do ? Why does it need 27v ? Does it attempt to simulate tubes with some jfet circuit, like a Fetzer valve circuit or a 12ax7ws ? Why are there 2(!) FV-1 chips in it ?
Apparently, it's a Binson Echorec clone--multihead drum echo/delay.
I thought it was a delay for drums, it's a magnetic drum head instead of tape
Catalinbread also has an echorec pedal, btw.
Since this is a production pedal instead of a DIY project, though, most manufacturers will offer repairs or replacements for nonfunctional pedals--does Dawner Prince no longer exist?
27v is likely to provide some extra headroom so the signal doesn't distort. However, having said that there will be regulators to knock that down for the FV1 chips which operate at 3v3, IIRC.
As for why 2 x FV1, I'm guessing it's to have extra "heads" in the tape delay or in this case heads per spinning-drums delay emulations.
