I was counting on you to have a solution! Both can be easily done, which one do you recommend?That can be accommodated by either reducing some resistors or increasing the power supply voltage.
There you go:Can anyone measure couple 2N3819 for me? I have the datasheet but I'd like to know Vp and Idss taken from the actual transistors. 4-5 pieces would be perfect.
Vp (V)  | Idss (mA)  |
2.91  | 6.6  |
2.32  | 4.3  |
1.64  | 2.1  |
2.75  | 5.9  |
1.82  | 2.8  |
2.94  | 6.7  |
2.55  | 5.4  |
1.82  | 2.6  |
2.70  | 5.9  |
3.01  | 7.0  |
Sadly... I originally bought 40 of them in hopes of finding matching sets for some phasers.Quite a spread.
Found the e-mail. I bought them at a brazilian store called Compomil (not sure if they do exports, customs clearance can be tricky here in Brazil), back in 2014. They were ~$0.25 back then.Yeah, it's a crap-shoot.
Would you mind telling us where you bought them and the price?
Definitely showing the biggest downside of FETsQuite a spread.
Vp varies 1.84:1
Idss varies 3.33:1
Can you share where you plan to use them? I have quite a few of them that I'd be interested to use
I was going to ask the sameWould you mind telling us where you bought them and the price?
I plan to test some Mad Professor circuits and 2n3819s are used there as clippers.
				Now you have me curious, is it necessary to select for Vp/Idss when using jfets as clippers?
| Model | Vp | Idss | FV |
| MMBF5457 | 1.224V | 2.435mA | 0.735V |
| MMBF5457 | 1.283V | 2.58mA | 0.738V |
| MMBF5457 | 1.430V | 2.84mA | 0.739V |
| MMBF5457 | 1.478V | 3.15mA | 0.744V |
| MMBF5457 | 2.012V | 3.14mA | 0.739V |
| MMBF5457 | 2.1V | 4.93mA | 0.755V |
| MMBFJ201 | 0.600V | 0.341mA | 0.749V |
| MMBFJ201 | 0.530V | 0.264mA | 0.741V |
| MMBFJ201 | 0.828V | 0.686mA | 0.742V |
| MMBFJ201 | 0.945V | 0.833mA | 0.736V |
| MMBFJ201 | 0.740V | 0.564mA | 0.743V |
| 2SK208R | 0.606V | 0.506mS | 0.702V |
| 2SK208R | 0.613V | 0.52mA | 0.702V |
| MMBF4393 | 1.76V | 12.5mA | 0.712V |
| MMBF4393 | 1.99V | 14.5mA | 0.705V |
| MMBF5458 | 1.73V | 3.66mA | 0.731V |
| MMBF5458 | 1.6V | 3.31mA | 0.737V |
| MMBF5458 | 1.947V | 4.47mA | 0.734V |
| MMBF5485 | 2.427V | 5.9mA | 0.754V |
| MMBF5485 | 2.31V | 5.46mA | 0.752V |
| MPF102 | 1.785V | 6.44mA | 0.741V |
| MPF102 | 2.12V | 8.3mA | 0.742V |
| MPF102 | 1.99V | 7.7mA | 0.738V |
| J111 | 5.34V | 65mA | 0.683V |
| J111 | 5.241V | 63mA | 0.683V |
| J112 | 2.47V | 27mA | 0.720V |
| J112 | 2.894V | 34mA | 0.720V |
| J113 | 2.58V | 28mA | 0.722V |
| J113 | 2.270V | 24mA | 0.720V |
JFET as a clipper (shorted D and S) acts as a diode with forward voltage close to silicon diode. I've just measured several different JFETs. FV spans between 0.7V and 0.76V depending od the transistor model. There are rather small differences between same model transistors. Can you measure FV of the 2N3819 for a comparison?
In my opinion differences in FV of the same transistor model are small enough so there's no need to match them.
Model Vp Idss FV MMBF5457 1.224V 2.435mA 0.735V MMBF5457 1.283V 2.58mA 0.738V MMBF5457 1.430V 2.84mA 0.739V MMBF5457 1.478V 3.15mA 0.744V MMBF5457 2.012V 3.14mA 0.739V MMBF5457 2.1V 4.93mA 0.755V MMBFJ201 0.600V 0.341mA 0.749V MMBFJ201 0.530V 0.264mA 0.741V MMBFJ201 0.828V 0.686mA 0.742V MMBFJ201 0.945V 0.833mA 0.736V MMBFJ201 0.740V 0.564mA 0.743V 2SK208R 0.606V 0.506mS 0.702V 2SK208R 0.613V 0.52mA 0.702V 2SK208R 0.613V 0.52mA 0.702V MMBF4393 1.76V 12.5mA 0.712V MMBF4393 1.99V 14.5mA 0.705V MMBF5458 1.73V 3.66mA 0.731V MMBF5458 1.6V 3.31mA 0.737V MMBF5458 1.947V 4.47mA 0.734V MMBF5485 2.427V 5.9mA 0.754V MMBF5485 2.31V 5.46mA 0.752V MPF102 1.785V 6.44mA 0.741V MPF102 2.12V 8.3mA 0.742V MPF102 1.99V 7.7mA 0.738V J111 5.34V 65mA 0.683V J111 5.241V 63mA 0.683V J112 2.47V 27mA 0.720V J112 2.894V 34mA 0.720V J113 2.58V 28mA 0.722V J113 2.270V 24mA 0.720V
Forward Voltage  | mV  |
2sk246Y  | 734  |
2sk246Y  | 720  |
2sk304C  | 726  |
2sk304C  | 726  |
2n3819  | 752  |
2n3819  | 753  |
mpf102  | 758  |
mpf102  | 760  |
At what current are you measuring Vf? What matters is in a pedal circuit is the curve, not the voltage at a single point.
