JFET Shootout
Depends on the resistor values. Post the schematic you're using and I'll recommend something.
I'm using the rog tester with 100 ohm and 10meg resistors. My multimeter claims to have a 40MOhm input impedance. According to the 2n3819 datasheet, Idss can go up to 20mA
That will work fine as-is. If Idss = 20mA, the voltage drop across the 100Ω will be 2V.
Measuring Vgs,off is always a crap-shoot because the datasheet specs Vgs,off at some arbitrary drain current that rarely matches the drain current in these simple test jigs. But it will be close enough.
Can anyone measure couple 2N3819 for me? I have the datasheet but I'd like to know Vp and Idss taken from the actual transistors. 4-5 pieces would be perfect.
There you go:
Vp (V)​
Idss (mA)​
2.91​
6.6​
2.32​
4.3​
1.64​
2.1​
2.75​
5.9​
1.82​
2.8​
2.94​
6.7​
2.55​
5.4​
1.82​
2.6​
2.70​
5.9​
3.01​
7.0​
Can you share where you plan to use them? I have quite a few of them that I'd be interested to use
Thank you very much for the measurements :)
I plan to test some Mad Professor circuits and 2n3819s are used there as clippers.
I am not sure if I want to pay $1 each so I was curious if I could use a substitute I have in stock. Looks like MMBF5457 might be a good candidate. I have some 57s with high Vp/Idss. Another thing is that I don't know what Vp/Idss those used by Mad Prof have.
Would you mind telling us where you bought them and the price?
I was going to ask the same :)
There's one or two local sellers with 2N38198 in stock but the price is too high as for me - close to $2. Ebay - China, China.. China.. and then expensive stuff from US/Canada/Australia. Looks like Mouser is the only realiable, not super expensive place to buy them.
@temol Musikding is €1,25
electronic-studio have these funky looking ones, but shipping outside Germany is a killer:
Now you have me curious, is it necessary to select for Vp/Idss when using jfets as clippers?
JFET as a clipper (shorted D and S) acts as a diode with forward voltage close to silicon diode. I've just measured several different JFETs. FV spans between 0.7V and 0.76V depending od the transistor model. There are rather small differences between same model transistors. Can you measure FV of the 2N3819 for a comparison?
In my opinion differences in FV of the same transistor model are small enough so there's no need to match them.
ModelVpIdssFV
MMBF54571.224V2.435mA0.735V
MMBF54571.283V2.58mA0.738V
MMBF54571.430V2.84mA0.739V
MMBF54571.478V3.15mA0.744V
MMBF54572.012V3.14mA0.739V
MMBF54572.1V4.93mA0.755V
MMBFJ2010.600V0.341mA0.749V
MMBFJ2010.530V0.264mA0.741V
MMBFJ2010.828V0.686mA0.742V
MMBFJ2010.945V0.833mA0.736V
MMBFJ2010.740V0.564mA0.743V
2SK208R0.606V0.506mS0.702V
2SK208R0.613V0.52mA0.702V
MMBF43931.76V12.5mA0.712V
MMBF43931.99V14.5mA0.705V
MMBF54581.73V3.66mA0.731V
MMBF54581.6V3.31mA0.737V
MMBF54581.947V4.47mA0.734V
MMBF54852.427V5.9mA0.754V
MMBF54852.31V5.46mA0.752V
MPF1021.785V6.44mA0.741V
MPF1022.12V8.3mA0.742V
MPF1021.99V7.7mA0.738V
J1115.34V65mA0.683V
J1115.241V63mA0.683V
J1122.47V27mA0.720V
J1122.894V34mA0.720V
J1132.58V28mA0.722V
J1132.270V24mA0.720V
I can measure them, but I don't know the test conditions on my multimeter. I can measure some of my MPF102 as well so you can compare to your measurements
ModelVpIdssFV
J1115.34V65mA0.683V
J1122.47V27mA0.720V
J1132.58V28mA0.722V
Forward Voltage​
mV​
2sk246Y​
734​
2sk246Y​
720​
2sk304C​
726​
2sk304C​
726​
2n3819​
752​
2n3819​
753​
mpf102​
758​
mpf102​
760​
Added a couple other jfets, just because
At what current are you measuring Vf? What matters is in a pedal circuit is the curve, not the voltage at a single point.
I found that JFETs have a Vf that is slightly higher than the usual signal diodes (1N4148, 1N914) and rectifiers (1N400x). I use BA482 diodes in the Mojito because their Vf curve is nearly identical to the 2N5457 (used in BJFe Model G) and 2N5952 (used in BJFe model H). Similar BJFe circuits use 1N4007 for the hard clippers. I think the differences are subtle at best.
Should an arrangement like this (with the diode in place of the resistor, of course) work for tracing the curve? I'm not sure if it'd be precise enough, though, with my multimeters
