You read my mind! I have a couple I wanted to do that to, then stamp in letters for labels (drop filling those), then hitting the whole thing with Duplicolor Metalcast (transparent colors). But the points you mentioned about a fence etc for spacing is the one thing I am considering. Just wish I had access to a milling machine where I could use the slides to keep straight.Finally managed to squeak in some pedal-build related time, yesterday.
I absolutely LOVE the look of engine-turned alumin(i)um.
I've mentioned it before.
Before I work my way up to hand-scraping ala Bugatti, as mentioned in this post, I thought I'd take a turn on machining an enclosure.
So I searched online "how-to" and a few results popped up, one of which was this Hackaday post. I like Hackaday, so I didn't even bother to look at others. Hackaday's suggestion? Toothpaste and a pencil eraser. I've got proper polishing compounds and wheels, but...
Well I cheated a little and went with a mildly abrasive Dremel bit, though I did go with an old stale tube of Crest;
Using a cheap 1590N1 clone's lid as a test bed, I began the experimintations...
View attachment 69170View attachment 69171
Friend's garage is heated or I would've used my own drill-press/garage, I started off working "free-hand" ( though not as free as if I'd used my own Dremel instead of a friends drill-press), and it was quickly obvious some form of a line was needed more than just a 2B-pencil's:
View attachment 69173View attachment 69174
See the Gap(s) above, especially at 8 o'clock relative the screwhole? Too much goo on the bit to see where to start the next circle.
Then some more experimentation with varying degrees of pressure, led to the material being worn down to the shaft of the bit.
This was expected, but it came about much sooner than hoped for. It left some damaging grooves in the centre of these circles:
So I had to swap out the blue bit for a smaller white bit, of a different compound.
Tried it dry, without toothpaste and with toothpaste, the latter was only marginally better but in both cases the white bit wanted to grab the alloy, too much so.
So I broke out the 2B-pencil's eraser, as per the Hackaday article, the smallest circles yet...
View attachment 69176View attachment 69177
Well, as you can see, between the crescents on the left by the yellow tape and the scratchings on the right by the edge of the enclosure lid...
The eraser barely gets the job done. It would take forever with pencil erasers.
Here's the entire lid. I started at the top and worked my way down. It looks like it should be the other way 'round, starting off poorly at the bottom and figuring it out by the time I got to the top. Alas, this was NOT the case:
Here's what I learned:
1 — A gate/rail will be mandatory to get evenly spaced circles — eyeballing it isn't going to achieve the desired result.
2 — When working with toothpaste, keep a small tub of water and PLENTY of paper-towels/shop-towels handy. That stuff WILL get everywhere.
3 — With the right bit, only light pressure is needed and let the machine do the work.
4 — Have plenty of the right bit on hand; this test run KO'd the first bit in no time. I'll have to experiment further to find the right bit material.
5 — It's easy, but time consuming, and I still love the look; I'm very satisfied with my first ever proper machine-turning results.
6 — A method to get even spacing between swirls and rows/columns is needed (see 1 above).
Suggestions on how to label it once it's turned are welcomed. Sort of leaning to a Fairfield Circuitry stamped letters with ink backfill. Maybe laser-etching. Will test those both on the lid in future.
Looking forward to finishing turning the pedal.
28mm seems HUGE for 1590N1. 1590 BB not as much. Are you going to overlap like Japanese woodcut-patterns?You read my mind! I have a couple I wanted to do that to, then stamp in letters for labels (drop filling those), then hitting the whole thing with Duplicolor Metalcast (transparent colors). But the points you mentioned about a fence etc for spacing is the one thing I am considering. Just wish I had access to a milling machine where I could use the slides to keep straight.
I also found these Velcro attached round sanding discs that are just under an inch diameter (28mm I believe for the metric folks), that I want to try. Hopeful.
Your Six Gun is one of my most favourite of your builds.Sorry to prolong this saga about one pedal enclosure but I wanted to offer up a cautionary note.
It’s super fun to have a really shiny enclosure. It looks cool. If you are using waterslide decals, it’s even better because waterslide decals LOVE super smooth surfaces. Film free decals, however, not so much – especially if you are so anal about the polishing as I am.
Long story short – I got the enclosure so smooth and mirror/like that when I applied the glue for the film decal, the glue actually beaded up on the surface and I could never get it to fully spread properly. I did my best and baked it but you can see a few places in the lower left corner did not adhere. Unfortunately, adding clearcoat made these spots even more visible so I’m just gonna go with the story that I was going for a wild West, shot all to hell look.
It will be a 125b size, so I have a little room And yes, I will overlap. Thinking by 50%, but may try 25% That’s what bottom of enclosures are for!28mm seems HUGE for 1590N1. 1590 BB not as much. Are you going to overlap like Japanese woodcut-patterns?
Looking forward to hearing how you go about it and seeing the finished enclosure.
What’s the circuit?My first use of the 0402 sized components. DIY, double sided board, with 0603 and 0402 caps and resistors. 0402 is doable hand soldered but a microscope would make the whole process easier.
Converting to 12 strings as well, or just mimicking the tuning?Gettin back into it while waiting on enclosures-
Woodpecker
XC Phase
Sunstone
Lumitron
Next up will be a Pepperbox and a Prismatic
And Bajo Sexto-ing this Squier Offset Telecaster
That's how I tune my VI.Converting to 12 strings as well, or just mimicking the tuning?
I assume that makes three of us, eh bricksy?I do want to do a 12 string 30" at some point, though
Awesome! Figured those 90s Teles were what you were after.Just the tuning. Back in the late 90s, Fender released a Custom Shop line of 30" scale length 24 fret Teles and Strats called the Bajo Sexto, so I'm borrowing the name
I’ve been looking for ages for someone who could make 28” and 30” XII conversion necks. Really want to build a true electric Bajo Sexto (hence the 30”) and a 28” for a regular 12 string would be perfect for my preferred C-standard 12 string tuning
I've got one of those, but wish I'd just done the thing and gotten shell pink.And Bajo Sexto-ing this Squier Offset Telecaster
Haven't done bari or VI strings, but I've grown fond of C# tuning with power slinkys. Only one whole step from bari though : P which reminds me that I need to restring.
Have you thought about upgrade parts? I'm thinking I definitely want a six saddle bridge and maybe a P90 somewhere, but I love the stock bridge pickup. Decisions… kinda nice they route all of those bodies the same so they can be jazzmasters, jaguars, or whatever.
