Thought they were opposing clippers. Didn’t realize they were facing each other like that. I’m also curious to the theory behind it.I’m learning, and I’m always seeing something new. What is the purpose of the zeners facing each other in the gain feedback loop?
I got some wicked buzzing in mine.Thought they were opposing clippers. Didn’t realize they were facing each other like that. I’m also curious to the theory behind it.
All I know is I threw one together yesterday and love it!!
Did you use a breakout for the switch and have the leads to the jacks up and away from the board?I got some wicked buzzing in mine.
It’s still on my testing rig.Did you use a breakout for the switch and have the leads to the jacks up and away from the board?
That could possibly be part of the problem. This circuit is brutally high gain and susceptible to being noisy and and oscillating if all of the building “best practices” are followed.It’s still on my testing rig.
I was wondering about that.That could possibly be part of the problem. This circuit is brutally high gain and susceptible to being noisy and and oscillating if all of the building “best practices” are followed.
It's just almost an electrical buzz on pin 3 of I.C. 2. It's driving me nuts.Did you use a breakout for the switch and have the leads to the jacks up and away from the board?
Battery or ac adapter? Your description makes me think some kind of power supply couplingIt's just almost an electrical buzz on pin 3 of I.C. 2. It's driving me nuts.
Adapter. I think I may have to remove the pot next to the switch and go over everything again. Some of the grounded parts were difficult to solder.Battery or ac adapter? Your description makes me think some kind of power supply coupling
It really behaves like a high gain tube amp in that it don’t take much to induce noise or buzz.Adapter. I think I may have to remove the pot next to the switch and go over everything again. Some of the grounded parts were difficult to solder.
I will try it with a battery and also wrap some shielding around it. I did take it to another room with the same results.It really behaves like a high gain tube amp in that it don’t take much to induce noise or buzz.
Can you quickly test with a 9v battery instead of the AC?
I’m still confident that you have it built right and its environmental factors causing your problems.
If he does it and it works, I wouldn’t expect to see him again for a few weeks, as he won’t be able to stop playing it. Such a great pedal! Makes my Princeton, at bedroom volume nearly indistinguishable from my SLO30!Did you box it, my dude?
I would try that first. At least stick it in the enclosure with the jacks attached.
