iamjackslackof
Howdy gang,
Got a couple questions about the Fuzzy Foxx.
1. My reading of the schematic says that D1and D4 produce the octave, and D2 and D3 are the clippers. Is that accurate?
2. How closely matched to the octave diodes need to be to each other, and is there a range they should be in?
3. The guy I'm building this for wants a stomp switch for the octave switch. I'm not certain how to wire a 3PDT in this case. I'm guessing I would just connect one side of the 3PDT to the existing switch pads in the same order? I imagine I could order a SPDT stomp switch, but I have plenty of 3PDT on hand already. I also have SPST stomps I normally use for relays, could that work here too? I doubt it, since they're usually momentary and only have 2 poles, right?
Thanks!
Thanks!
