- Build Rating
- 5.00 star(s)
I always dug the Pitch Pirate demos a bit more than it's cousin, the Clarinot, so finally got around to building one up. Nothing too crazy going on here build wise. I read on here at some point that the lcr0203 worked fine and I would agree. From my recollection of pt2399 delay (Deep Blue?) you can get a decent delay without the noise. This does not seem to be the case here. I wish I had it still around to determine whether it is the chip or circuit. I tied a few different pt2399 though. Anyway, LED isnunfer the graphic which i don't normally do, but I fodnt want to mess up the witch. Added bonus it illuminates with the rate!
Once I stopped being concerned about the drlay noise, I has a lot of fun fiddling with this one. With the blend you can do chorus or vibrato. The depth and wave can give you seasick and chop. My favorite settings started with the blend more on the clen side and layering the modulation underneath. The delay noise becomes a nonfactor and you can get some cool textures going on with setting the feedback close to infinite.
Build wise this was very straightforward with no issues. I may end up lowering the delay pot value to focus on the shorter delay times
