Crack it open!My Fostex x-15 doesn’t function. But it was my high school sweetheart. I can’t let her go. Hahaha
If you don't need a multi-head unit for simultaneous write/read, I'd suggest whatever is available/cheap that looks to have somewhat sturdy build quality.Anyone have recommendations for a decent cheap portable player to circuit bend for tape loop playback?
You can also just use any regular tape player and make loop cassettes. Somewhere I have a recording of a loop cassette I made where I put diffeent synth pad notes on each track, and using the faders you can make chord changesAnyone have recommendations for a decent cheap portable player to circuit bend for tape loop playback?
Belts are intact. Like any troubleshooting, what are its symptoms?Okay
It's reportedly not a very good formulation and/or maybe the same as the tascam reissue stuff. It's been a while and my mind is foggy on it. I've used NAC for cassette reproduction for releases thoughFwiw, National Audio Co has been making type II for a while
I've seen some reports on that. Also wondered how much was unrealistic expectations. Only gonna get less badder without noise reduction. Maybe type IV will shown up one day.It's reportedly not a very good formulation and/or maybe the same as the tascam reissue stuff. It's been a while and my mind is foggy on it. I've used NAC for cassette reproduction for releases though
To be clear, I gave it away on craigslist (don't use Facebook), didn't toss it.I've seen some reports on that. Also wondered how much was unrealistic expectations. Only gonna get less badder without noise reduction. Maybe type IV will shown up one day.
I pushed a 1/4 teac 4 track and dbx unit out to the roadside about a year ago. Always wanted to get it fully working but never had the drive and wanted the sq footage back.
There's a little metal tab on the upper right of where the top of the cassette would go. It's generally just a mechanical switch but if it's pooched it tells the system that the record lock tab has been punched out on the cassette and it won't let you press record.It won’t allow you to press play and record at the same time. And one of the belts is a close approximation of a replacement. It has trouble fast forwarding with a cassette in the dock. But it can without one.
It’s been years since I’ve tried any thing with this old girl.
