- Build Rating
- 4.00 star(s)
I've finished this build today, a little bit ahead of schedule. I've only spent a while today playing with it and monitoring through headphones, but I'm very pleased with it so far, and looking forward to trying it at volume through a power amp. Particularly enjoying the boost from the bass control, and I'm looking forward to experimenting with this in conjunction with the HPF.
I've had the boards for this for a couple of months, and have slowly been gathering the parts from various UK suppliers. I did use the Lightning Boy MC15 transformer, since it ended up as being about the same as sourcing something in Europe. Valves are JJ Electronic ECC802s. Onboard DI volume trimmer has been moved to a panel mounted pot - at present this is a 500k linear pot, but I'll replace it with a log pot once it arrives. This is the only thing justifying my overzealous "/apr" dating in my labelling of the enclosure.
I _think_ my labelling of the HPF is correct, but it's my first time attempting to calculate the slope of a filter.
Biggest issue was sourcing 100uH 2.1A inductor, so I've ended up with one that's fairly massive that overlaps other components. Having read some other sushibox threads today, I think I could have used one with a lower amperage, but
The enclosure was hand drilled, largely following the positions from the tayda drill templates. The DI volume was squeezed into the only place I could find to fit it around the other controls, but this necessitated moving the 3/4" jacks along a bit. I had been considering mounting the ground lift switch on the top, mostly to avoid cutting the switch slot, but think I managed a pretty clean result with a 4mm drill bit and a file. I had some leftover 3mm hole/4mm pitch steel grill that I used as a template when drilling out the valve vents. I don't normally sand down my enclosures at all, but I ended up taking some to it to deal with the burr left from all the small holes - I don't think I did a great job of it, and I hope the aluminium oxidising eventually makes it less apparent, though the bright light doesn't help.
