AionFX Cygnus
VanWhy
4.00 star(s)
Lately I'm a sucker for the "hybrid" Ge/Si transistor fuzz based pedals. This is compared to the Cornish G-2. My plan for this one is to do the stock version and the version with the mods suggested by AionFX. This one is stock. And I can echo all the other reviews that say it's super dark and low output. I still think it sounds good with all controls maxed but just not great. I'm excited to build the modified one.
I also don't know why I built this one instead of the PPCB version. But I did. I bought the P-2 from PPCB and am looking forward to that build since I heard very good things about it.
Easy build. 4/5 for the circuit.
@VanWhy did you do the resistor mod on this ? I am on a constant G2 journey but just cannot get a pedal to sound like demos on the internet. No issue with the darkness, it’s more the lack of drive.
The only resistor mods I did was for R18 (15k to 18K) and R19 (680R to 100R). This is supposed to help the gain stage prior to the diodes. From what I hear the diodes are pretty critical. If the forward voltage is too low it's not going to drive properly.
If you don't have gain, then you need check those Germanium diodes (D2 thru D5 on Aion Cygnus v2.0.0 doc) - you absolutely need low leakage diodes (in reverse bias) plus forward voltages >0.3V, or you'll have low gain. This has been discussed elsewhere here, e.g., here:
I measured my Ge diodes before mounting them in the PCB, and I have no gain problem at all. There are also several threads on the PPCB Forum on measuring diode leakage, search for those by @Chuck D. Bones. And if you don't have the measurement capability, then you can socket the diodes and try out candidate diodes seeking the greatest gain.
Good luck - quality Ge diodes are increasingly hard to find, so the AionFX doc also provides alternative options such as the BAT41 with associated resistor changes. And they also suggest a modification for decreasing the bass output. But first fix the gain.
Here was my Aion G-2 build: https://forum.pedalpcb.com/threads/cornish-g-2-clone.21117/
