So just finished the build, led comes on, but no sound (barely any - I can hear the tiniest bit of guitar signal through the amp). Bypass works fine.
Voltages on the ICs read:
IC 1 (LM833N)
Pin 1 4.70v
Pin2 4.70v
Pin 3 4.28v (and both clipping LEDs light up)
Pin 4 0v
Pin 5 4.54v
Pin 6 4.54v
Pin 7 4.54v
Pin 8 9.07v
IC2 (TL072CN)
Pin 1 4.55v
Pin2 4.55v
Pin 3 4.55v
Pin 4 0v
Pin 5 4.54v
Pin 6 4.54v
Pin 7 4.54v
Pin 8 9.07v
Not sure if this is the “correct” way to measure the pin voltages, but I’m putting the black lead of my multimeter on the center lug of the switch (which I believe is ground), and then the red lead on each pin.
Any thoughts?
IC 1 (LM833N)
Pin 1 4.70v
Pin2 4.70v
Pin 4 0v
Pin 5 4.54v
Pin 6 4.54v
Pin 7 4.54v
Pin 8 9.07v
IC2 (TL072CN)
Pin 1 4.55v
Pin2 4.55v
Pin 3 4.55v
Pin 4 0v
Pin 5 4.54v
Pin 6 4.54v
Pin 7 4.54v
Pin 8 9.07v
Any thoughts?
