so I picked up a silver label sd-1 to compare to my black label. (Silver is on the right in pic).
Volume at 9 o’clock and gain at 8 o’clock (almost off) the silver label has this hum and it gets super loud the more you turn up gain and/or volume.
I tried it with a battery and no change.
I then took a look inside and it look unmodded. I then started moving around a few wires and the battery cable it super microphonic when tapped on.
The other wires for power are slightly phonic but nowhere near as bad the the battery cable.
I checked pins 6/7 of the 4558 chip is right around 32k with gain off and 989k all the way up so the gain pot looks good.
Any one come across this before.
Any suggestions?
Thanks
Any suggestions?
Thanks
