mkstewartesq
(If this should be in Troubleshooting", my apologies - but it isn't a pedal problem so I was unsure).
So, before I run off to a dedicated amp forum where I don’t know anyone, I thought I would first ask this question of all the knowledgeable people here I trust:
I have a vintage 1968 Fender Deluxe Reverb (early silverface with drip edge), AB763 circuit. I’ve owned it since 1984 but not played it in a while so I had a well-known local amp tech go over it and get it back up to speed. But I’m guessing he didn’t test it by playing loudly.
At anything above about 3.5 - 4 on the volume, you get a deep rumble on the bass notes - it swells and then fades, and almost has a phasey quality. It will do this sooner if you use a guitar with higher output pickups (or with single coils wired in series) or even if you roll the tone knob off so the guitar is mainly pushing bass frequencies. Driving it with a compressor has the same effect. Anything above that volume is just fuzz city and unusable.
Both channels (normal and vibrato) exhibit the same behavior. Treble at 6, bass at 3. I tested with an external speaker and the external speaker reproduced the same sound, so my internal speaker doesn’t appear to be the culprit.
I found this video online which is a pretty good representation of the sound – but in all the threads I’ve searched, no one has offered a good solution.
Any thoughts or suggestions from the brain trust here?
As always, thanks.
Mike
As always, thanks.
Mike
