Those two are the same value?
Is the new one rated for a significantly higher voltage or something?
I built a device that switches polarity on a cap, and you plug it into an amp. This is to find the noisiest end, which is the foil end and needs to point to the part of the circuit with the least impedance. You simply put the cap next to a neon light or other very noisy device, and flip the switch.They are both .047uf I believe. The smaller MAY be a .022uf. The orange drop is 400v, not sure what the one that came off my strat is. I have read on the forums that the orange drops are "night and day" better so gonna give it a try,
Don't forget dielectric! Some are polyester, some are polypropylene. Polypro tends to be larger given the same value.Orange drops can get quite big, depending on value and rating. I guess they must be big to contain all that toan.
ToanZZZ don’t forget the Z! And it depends on the ballz and sometimes also on their filling level.
Very hard to find bearded capacitors these days.Do I need the ZZ to get the ZZ Top sound or do I need to add a beard?
Come on everybody, we all know the bigger the capacitor the better and bigger the toan! Huge PIO caps? Fuhgedaboudit! TOOOOAN!
You just need to get yourself that Big TOAN Energy!
It applies to other things in life like penises and Nissan Altimas.
