Thanks for detailed information! I will study and digest your message.Leaving the inputs of unused opamps or CMOS floating is an absolute no-no. Unpredictable & generally bad things can happen. I can understand why a builder might use only part of a dual (or quad), but leaving unused inputs floating is bush-league.
If you want to put the spare opamp to good use, wire it as a unity gain buffer and stick it between the TREBLE & VOLUME pots. you'll have to relocate C3 after the buffer.
The other thing J Rockett did that is problematic is connecting a capacitor from an opamp output to ground, which is what happens with C8 when TREBLE is dimed. A capacitor between the output & ground can cause instability if the capacitor is too large. How large is too large? Hard to say because it varies from mfgr to mfgr & lot-to-lot. It also depends on the feedback network. Sometimes the datasheet provides guidance. Better to avoid the problem altogether. A 100Ω resistor between the opamp's output and the load capacitor is sufficient to ensure stability, so J Rockett could have done that.
Hello Chuck, if I understood correctly you mean the modifications like below. With these modifications, with the help of unity gain buffer we will have low impedance at the pin 7 and solve stability issue using 100R resistance. But tonewise, what do we expect to have? I guess less noise because no more unused op-amp and 100R resistor, but the sound of the pedal remains same?Leaving the inputs of unused opamps or CMOS floating is an absolute no-no. Unpredictable & generally bad things can happen. I can understand why a builder might use only part of a dual (or quad), but leaving unused inputs floating is bush-league.
My first post. This is an amazing forum and I am very impressed by some of the builds and info I am seeing. So what components or design make the Majestic pedal a so-called Jimmy Page HTWWW (as advertised by JRAD, anyway) tone Marshall in a box vs other MIAB pedals? Thanks!For anyone who wants to try a Majestic - and I would very much recommend it - here is the schematic. Apologies if the schematic layout is wrong - I never studied electronics so don't know exactly how to do these things. But everything is correct as far as I know.
The only mods I have done to this circuit is replace the Ge diodes with 1N4148s and the 100K gain pot for a 250K. The 1N4148s don't actually sound very different - maybe a hair brighter but it's not a big difference. I really like the combo of 1N4148s with 1N4001s. Could be just my perception but it sounds a tiny bit less shrill than all 4148s and clearer than using the Ges. As usual, I could be talking outa my bum but this circuit does it for me! FWIW I find this circuit to sound a lot like the Caliber 45 (strange, huh?) but it has a bit more low-mid content. It works incredibly well at the clean to dirt transition thing, and all with bugger-all parts. Fab.
View attachment 3322View attachment 3322
You could put the Rxx either where you have it or between SignalFromPin1 and TREBLE pin 3. I'd use C10K, not B10K. The buffer is not absolutely, but does isolate the next device from the Treble network. If you use the buffer, VOLUME could be as low as 10K. I'd use A-taper for VOLUME, but it's a personal preference.Hello Chuck, if I understood correctly you mean the modifications like below. With these modifications, with the help of unity gain buffer we will have low impedance at the pin 7 and solve stability issue using 100R resistance. But tonewise, what do we expect to have? I guess less noise because no more unused op-amp and 100R resistor, but the sound of the pedal remains same?
Yeah, good question. It's amazing how many pedals claim to "nail the Jimmy Page tone" as if Jimmy only had one tone. He didn't always use Marshalls, he didn't always play a Les Paul. He had his gear modded and he knew how to get the most out of his gear, the studio and the mix.My first post. This is amazing forum and very impressed by some of the builds and info I am seeing. So what components or design make the Majestic pedal a so-called Jimmy Page HTWWW tone Marshall in a box vs other MIAB pedals? Thanks!
Thanks, learning a lot from this forum. In your opinion, of these two types of circuits which one do you think would stack better with other overdrives, Klones, and fuzzes?The BluesBreaker is an original design. Other pedals are based on it.
Both the BB & the Majestic use opamps for gain and diodes in the feedback path for clipping. Their tone shaping (freq response) circuits are different. There is a lot of overlap in their tonal ranges.
There is an overload of ODs, more than just a klutch of Klones, and a flash flood of fuzzes that flow from pedal makers — then there's a diverse diaspora of departures in playing styles, a magnitude of musical genres to choose from, more than a gaggle of guitars to be played, a pantheon of pickups to pick from, an avalanche of amps and tons of tones ... not to mention a plethora of people's personal preferences.Thanks, learning a lot from this forum. In your opinion, of these two types of circuits which one do you think would stack better with other overdrives, Klones, and fuzzes?
Sir, my mind is officially blown.There is an overload of ODs, more than just a klutch of Klones, and a flash flood of fuzzes that flow from pedal makers — then there's a diverse diaspora of departures in playing styles, a magnitude of musical genres to choose from, more than a gaggle of guitars to be played, a pantheon of pickups to pick from, an avalanche of amps and tons of tones ... not to mention a plethora of people's personal preferences.
Where and how did you want to begin narrowing it down?
These are some of my areas of interest:
High-gain Bar-room blues-lawyer noodling;
Djently strumming modern clean-chorused chords on folk-songs of the working masses;
Travis-picking cross-bread at the crossroads with sweep-picking-a-la-Frank-Gambale with added tapping of Stanley Jordan-meets-Ed VanHalen with a touch of Roy Smeck, Harry Webster, Tal Farlow and Barney Kessel digitally sampled in...
I had a similar reaction one night when 'Immigrant Song' from HTWWW came on a local FM station playing selections from the album. Had never heard it before, but the lead break sounded massive. I did read somewhere that he re-amped his guitar parts most likely, so maybe that explains it in part anyway.Apologies for the off-topic detour...
Agreed! But personally, I find his How the West Was Won (HTWWW) guitar tone particularly compelling. I only learned of the existence of HTWWW in 2020 or 2021. One of the tracks from that album came on the radio, and I quite literally sat up in my seat: one, because I'd never heard that version of the song, and two, the guitar tone was (again, to my ears) the definition of what a rock guitar should sound like. (And despite being a pretty big Zep fan, I never really chased Jimmy's tone prior to hearing that.)
So I did some research, trying to see if there was any Internet wisdom as to how he got those sounds. And I came to the conclusion that what we hear on HTWWW is at best tweaked from how those tunes sounded when they were performed, and at worst heavily post-processed and engineered to Jimmy's tastes. Read about Kevin "Caveman" Shirley, the famous engineer Page hired to work on HTWWW.
