Hooligan Mini (Kliché Mini)
Dumb question, is this a single water slide and if so how do you know your placing the knob labels in the right spot? Anytime I’ve used water slide I cut the labels out individually but it doesn’t look as clean.
Measure everything, use shapes the size of your knobs (or knobs from a library) when making your design, you hide them in your final print. Make a few test prints on paper if needed to ensure right alignment.
Great info! I’ll give it shot. I struggled with my laser engraver as well and some of this may help that too.
Reactions: Nic
It’s a single decal. I printed small alignment dots with the label. You center the dots over the holes when the label is placed. They get cut out when the label dries.
