The smaller ones are meant for 125B sized circuits. The hole layouts will directly fit any 3 knob or 4 knob circuit @Robert makes!And with different control setups! What size is the smaller ones?
penny drops - they are sheets of metal to be bent! I thought I was looking at the top of die cast enclosuresThe smaller ones are meant for 125B sized circuits. The hole layouts will directly fit any 3 knob or 4 knob circuit @Robert makes!
That would be really cool though! I would love to get into stamping or casting one day!penny drops - they are sheets of metal to be bent! I thought I was looking at the top of die cast enclosures
Do it!!!!!!That would be really cool though! I would love to get into stamping or casting one day!
In your opinion would aluminum be easier to work with?I've done bronze casting in my art college days, pain in the bottom. Only benefit would be being able to do non flat/square shapes
Cheaper, but not necessarily easier. A lot of thought needs to be put into your sprue system so you get full fill and no air pockets. Sand casting is the most cost effective process probably. Die casting would be easiest after setup, but it’s a huge hurdle in terms of cost and effort to create a die first. Lost wax (or ppla) gives the most freedom as far as design and detail go, but it produces a lot of waste, and it takes a lot of setup for each cast— great for one-offs, but the hours that would need to go into each casting would make it totally unprofitable to sellIn your opinion would aluminum be easier to work with?
Will you do the any of small ones with the LED between the pots? Also a 6 knob would be sick for any of the blackout 6-knob muffs (Musket/Bayonet; Blunderbuss/Thunder Pipe)The smaller ones are meant for 125B sized circuits. The hole layouts will directly fit any 3 knob or 4 knob circuit @Robert makes!
Thank you for the detailed response!Cheaper, but not necessarily easier. A lot of thought needs to be put into your sprue system so you get full fill and no air pockets. Sand casting is the most cost effective process probably. Die casting would be easiest after setup, but it’s a huge hurdle in terms of cost and effort to create a die first. Lost wax (or ppla) gives the most freedom as far as design and detail go, but it produces a lot of waste, and it takes a lot of setup for each cast— great for one-offs, but the hours that would need to go into each casting would make it totally unprofitable to sell
The LED can be done no problem! I would just need to get through this batch and that can be a hole layout i offer in the future! 6 knob layout in any fashion can be done as well!Will you do the any of small ones with the LED between the pots? Also a 6 knob would be sick for any of the blackout 6-knob muffs (Musket/Bayonet; Blunderbuss/Thunder Pipe)
I’ve never actually done any sand casting, but I’m totally fascinated by the process and have spent a lot of time reading/ watching videos about it. This YouTube guy is probably the reason I got interested:Thank you for the detailed response!
Sand casting sounds like the way to go then. Any particular type of sand you would recommend? Im sure there are different compositions and mixtures. In your opinion whats the best to use?
Thank you for the resources!I’ve never actually done any sand casting, but I’m totally fascinated by the process and have spent a lot of time reading/ watching videos about it. This YouTube guy is probably the reason I got interested:
PATTERNMAKING- foundry - casting
Share your videos with friends, family, and the worldwww.youtube.com
My brother in law does it for car parts, let me talk with him to see if he has any suggestions.I’m super bored and want to get into powder coating since I hate paint so much. Anyone have thoughts?
Its not too hard to get into. You can do a lot of learning with a cheap toaster oven and the Harbor Freight Powercoat gun. I used that setup for about 4 years until I decided to upgradeI’m super bored and want to get into powder coating since I hate paint so much. Anyone have thoughts?
A simple oven like the Jegs powder coat oven and an Eastwood dual voltage gun would be a great place to start. Although not needed the stand from Eastwood for hanging parts will help out tremendously.I’m super bored and want to get into powder coating since I hate paint so much. Anyone have thoughts?
What he said!Cheaper, but not necessarily easier. A lot of thought needs to be put into your sprue system so you get full fill and no air pockets. Sand casting is the most cost effective process probably. Die casting would be easiest after setup, but it’s a huge hurdle in terms of cost and effort to create a die first. Lost wax (or ppla) gives the most freedom as far as design and detail go, but it produces a lot of waste, and it takes a lot of setup for each cast— great for one-offs, but the hours that would need to go into each casting would make it totally unprofitable to sell
