Angry Charlie -squeal/feedback/noise
CheapSuitG
The TubeSchemer
Hi!
Built an Angry Charlie, sounds cool but getting this crazy feedback squealing sound when have the gain cranked. Also the volume and mids cause it when cranked.
Even with the guitar unplugged it’s squealing. I can see it hitting the leds and engaging them.
I tapped on the case to see if there may be something stuck like a clipped capacitor leg and could hear the tapping through my amp. Also accidentally knocked over cellphone my desk/bench and the pedal picked that up as well.
Also a fair amount of hum, even with no guitar plugged in.
Tried:
Reflowing everything.
Reseating the ic.
Different power supply (saw the adhd post about the noise, it’s a different squeal, more feedback)
Left to the kitchen, ate a slice of pizza hoping that would help, it did not.
Thoughts?
Do you have a buffer (or pedal with buffered bypass) you can try in front of it?
A few folks have reported squealing at high gain settings... I need to build one of these and see if the layout needs revising.
EDIT: Just did a bit of Googling and it looks like a few folks have experienced squealing with the original JHS Angry Charlie as well as the Sweet Tea... So maybe it's "normal", but maybe we'll still try to fix it.
I knew it was a good idea to keep an un modified DS-1 around!
So - connected the ds-1 while unplugged from power, that reduces the noise. Powered it up with the ds-1 off and the angry Charlie started squealing again although different note.
That said, I’ll never dime the gain, there is plenty.
Is you enclosure sufficiently grounded? The ground connection between board and enclosure is the 1/4" jacks, and the inside is painted. Removing a bit of the paint on the inside around the hole would probably be a good idea, although at best it may only minimize your O.G problem..
I will double check although it will be a while. We are expecting a snow big storm and cold front starting this afternoon with a high Saturday of 4 degree Fahrenheit. I am NOT going to be working in the unheated garage!
While it's squealing, try spreading these wires apart.
Also try rerouting the yellow in/out wires.
I will try that this evening!
