FuzzyLotus
So. I'm currently building yet another Pedal with 4 SPDT toggle Switches.
I usually remove the notched washer, then put the first nut, then put the spdt through the hole in the pedal, then put the "teethed" washer, then the last nut, is that how you should do it? I've always assumed this was the way to do it but never bother to ask around. What is the purpose of the notched washer ? Cheers!
