jessenator
Ehhhhh, maybeDidyou do the ground pool around the 308? Not sure how often it's actually done in pedals...
 . I changed the layout a bit since that screenshot.
 . I changed the layout a bit since that screenshot.So, an isolation ring connected to Vref for a typical Rat circuit? I’d have to check my TO-99 package footprint, but implementing that would most likely require a rework.Input guarding rather...
Just wondering if anyone actually follows datasheet recommendation. I'm guessing few to none.So, an isolation ring connected to Vref for a typical Rat circuit? I’d have to check my TO-99 package footprint, but implementing that would most likely require a rework.
I haven't ordered adapters like this in quite a while, so I'm struggling to remember what their minimum dimensions are. I want to say it's 10x10mm... might have to be panel-ized if it's smaller, maybe? I'm also not sure about the threshold for shapes, but typically curves are fine. If it's overly complex, they just tack on an engineering fee, but that shows up in the item in the cart before you check out.I'm just starting to get into DipTrace and created this JFET adapter board. Can I just export this as gerber + NC drill, upload to JLCPCB and be done with it? It's literally just a board outline, pads and traces. It looks fine in the gerber viewer. Are the rounded corners going to be an issue?
I just checked, it's 5x5mm minimum size, so that'll work. I'll just give it a try and see how they turn outI haven't ordered adapters like this in quite a while, so I'm struggling to remember what their minimum dimensions are. I want to say it's 10x10mm... might have to be panel-ized if it's smaller, maybe? I'm also not sure about the threshold for shapes, but typically curves are fine. If it's overly complex, they just tack on an engineering fee, but that shows up in the item in the cart before you check out.
I’ve got some mk1 Motorola 308s that mention this in the datasheet. Do you have the rest of that document or is that just a snapshot?Input guarding rather...
It's just a snip from the datasheetI’ve got some mk1 Motorola 308s that mention this in the datasheet. Do you have the rest of that document or is that just a snapshot?
