mkstewartesq
Now, I remember reading right when I joined this forum to avoid ICs from Tayda - so while I did order some before I joined this forum, I immediately segregated them as “last resort” ICs and only use ICs purchased from Smallbear, StompboxParts, GuitarPCB, etc.
But I was building a verified stripboard Fat Rat and needed an OP07 so threw a few OP07CPs in my Tayda cart because they were relatively inexpensive and I was ordering a lot of other stuff at the same time. That build ended up sounding like shit (honky, kind of like a half cocked wah, sputtery in the decay, and not much gain to start with and less and less gain the higher you moved in the frequency range/up the neck). I chalked that up to maybe me screwing something up in the build.
So I did a stripboard build based on the JHS Triad Distortion, which is basically a Rat, and got the exact same results. I double checked all my values and placement (I’m actually a nerd who checks all the values on the multimeter BEFORE I even put them on the board) and I’ve sawed between the tracks to eliminate possible shorts so much that I can now roll up the board like a bamboo mat.
So I tried putting a TLO71 since it is at least pin-compatible, and actually got some really good sounds, and at least about the level of gain and distortion I would expect from a Rat, even if not the exact sound. But none of my OP07s sound good at all.
I’m resigned to giving up on the stripboard and will just buy a Muroidea or Triad board and buy some OP07s from Robert then or elsewhere if I’m placing an order. But has anyone had any issues with these chips from Tayda, or any suggestions on how I can test them so that if they are in fact bad I can let Hugo know?
Mike
Mike
