yerblues
Hello everyone! I'm in the process of building three Tommy III pedals but so far the first two haven't worked. the light lights up but there is no sound coming through when effect is engaged, true bypass works as intended and passes a signal though. I checked resistor values as I was installing them, and during my troubleshooting I reflowed all solder joints, I checked grounds and continuity between points and everything seemed to look good, and I also checked that the diodes are all working. Could it be possible I got a bad batch of electrolytic capacitors? I got all my components from Tayda.
Here are some photos. the Installed op amp isn't the one recommended in the sheet, it's a mod but I tried the recommended value as well and had the same no sound results. Sorry about the solder side pics, they came out blurry but I did reflow and check them. Hopefully someone can see something I missed.
