Better Way To Cut Stripboard?
Ginsly
I’ve been scoring both sides with an Xacto followed by a careful snap, but the breaks still come out a bit rougher than I’d like…
What are some better/cleaner/quicker ways to do it? I do realize that this can be nasty business, so I wear a mask and eye protection.:geek:
your method matches mine. and i think it’s fine.
but there’s another step.
i sand the edges round and smooth with x2 different grits and then finish with the last grit wet.
just cos it’s nicer like that.
Absolutely! I clean up the edges a bit, but it’s more that I wind up losing a row of pads sometimes due to the stripboard kind of chipping in an uneven way. Sometimes it’ll take the back off of the next row of pads when I snap it, if that makes any sense!
I use a handsaw. Wear a mask, you don't want to breathe fiberglass dust.
Still comes out rough though, and sandpaper fixes that.
Thanks all! Gonna try the Dremel. Lots of attachments available, is there a specific cutting disc you like?
I like generic metal ones you can get that have a rough coating on them, but the dremel brand ez-lock cut off discs are formidable.
edit: I break the dremel discs, I wear the abrasive off of these 1000001533.jpg
I use a Stanley trimmer to score each side quite firmly and snap the pieces apart. I don't often have chipping. I have a belt sander in my workshop so go out there, put the sander on its side and smooth the edges on that. Takes less than a minute. I wear a mask of course! Then i use the trimmer knife to scrape off the swarf and then brush any dust off with a stiff brush. It's all done in a couple of minutes and produces a nice smooth, clean edge.
I also use an boxcutter knife, sand the corners round, the sides flat.
Often stick it on a piece of upside down painters tape 50mm wide and spraypaint it black matt.
Just for looks.
I like black, but any colour is better than the colour of the veroboard itself.
Just for looks.
That's a neat idea. Looks awesome!
A ceran field scraper or only the razor blades that they use because they are sharp on one side. Perfect for cutting tolex too. A box cutter isn‘t a precise tool, more like a cavemen tool.
Yeah, my vero builds look like something a caveman would make.
I didn‘t write your vero looks like that, I wrote that it‘s not as precise as a single razor blade or a scalpel! Something you hold with your fingers vs something you hold with your fist.
