vigilante398
Authorized Vendor
Unagi E4305 is back in stock at C2C, you can buy them with a PCB or by themselves.
Honestly I'm not really sure. I wouldn't expect any noticeable difference at all between a 220uF bypass cap and a 221uF bypass cap, and the cathode bypass capacitor calculator on Ampbooks reflects this. I left it in because it was in the original I traced, and unless there's something I honestly consider bad design, I'll leave it in to avoid people saying "THAT'S NOT HOW IT IS IN THE ORIGINAL!" even if it doesn't particularly make sense to me.What is the reason for having cathode bypass capacitors C13 and C14 in parallel? Maybe someone asked before, but I haven't found anything.
Literally this:Any chance of getting boards of just the power supply section?
c2celectronics.com
Awesome. Thanks so muchLiterally this:
High Voltage SMPS PCB
This is a PCB for building a high-voltage “nixie” style power supply for tube projects. It has a trimpot to adjust the high voltage from about 30V-450V, be sure to choose the right rating for your …c2celectronics.com
All that said, Jack (designer of the Noble) is more educated than I am, maybe he just knows something that I don't.
Which makes me wonder if he did in fact use a film cap for the 1uF. I didn't take anazing notes during the tracing process, I just drew a schematic, so it's possible it could have been and I just don't remember. As cool as it would be to keep the original unit around to reference, that's a big investment to just have around to look at.That makes sense. I thought it was going to be this.Cudos for keeping it closer to the original. There is no downside if you don't think about the added cost.
I know about use cases in HiFi audio where people do this, but with a different type of caps because of lowering the ESR in specific applications. The ratio between them is usually also lower.
This is basically less than a 0.5% difference in the total capacity. That is an order of magnitude from the tolerance if you use really fancy 5% caps.![]()
The original does not have an XLR out volume control, it is fixed at what would be "maximum" of a Nobelium. I wanted to make sure the pot value was significantly higher than the impedance of the transformer's primary so it wouldn't impact the transformer's response, and I thought 500k seemed like a reasonable choice.I was studying the preamp a bit, and I have another question. Why is the XLR out volume 500k and not a smaller value? The 500k is too big for the transformer that expects much lower impedance, so it easily could be 50k, for example. The loading of the second triode wouldn't be a problem, but the C7 would have to be increased to 470n or something like that to keep the bass response.
I get that it is how it was in the original unit, but let's take this from an educational perspective.
Hey Smrtokvitek... I had someone ask me to build a Nobelium with a Jensen transformer... where did you find this almost mythical beast?Thanks, now I look at the transformer datasheets, and it should be fine. I was under the impression that the primary impedance is usually about the order of magnitude lower. With the Jensen, it should be fine to use 500k XLR pot with the 250k in parallel, as it expects 200k according to the datasheet, and the worst case should be 125k at 50% of the volume setting.
Ahh… cool.@SamuelG I did not. I was reading datasheets only. You can build it with other transformers, though. It is in the build doc. @vigilante398 is selling the E4305 one.
Ahh… cool.
Yes, I normally use the E4305 but he really wanted the Jensen name. Nearest I could find in stock with postage to Australia was closer to Au$400 than $300. Not worth it.
The only place I've ever been able to get them was direct from Jensen. I had to call their sales team on the phone and set myself up as a customer, then email a request for quote, agree to the quote, and pay the invoice. This was for an order of 3 units. It doesn't seem like they like catering to small builders.Hey Smrtokvitek... I had someone ask me to build a Nobelium with a Jensen transformer... where did you find this almost mythical beast?
I've been in this same situation for the past few months.Hey Smrtokvitek... I had someone ask me to build a Nobelium with a Jensen transformer... where did you find this almost mythical beast?
I’ve messaged the seller some days ago, but I haven’t had a response.Crazy money. There is a used one in Australia on Reverb right now.
I should have read further down the commentsI’ve messaged the seller some days ago, but I haven’t had a response.
