mdc
Hi folks
This is a bit of a utility build report, but hopefully some others will find it useful? In any case, I've had a few builds lately with switch pop that wasn't cured through the usual methods. In digging around for a solution, I found the schematic for optocoupler-based bypass that voodoolabs uses in their effects pedals and switching systems. It's incredibly simple and works exceptionally well.
The TLP181 is a DIP-4 smd device, but after asking around a bit it seems like pretty much any similar transistor-output optocoupler will do the job. I used a DIP-6 4N26 that I grabbed from my local arduino shop (tayda stocks these for about 20 cents each btw) to try it out, and it worked a-ok. Other devices should work, but YMMV.
Here's a vero layout for the DIP-6 / 4N26 pinout:
It's not noted on the vero, but B3 is pin-1, black is ground, red is power.
I've added this to two pedals so far that I couldn't otherwise rid of switch pop and it's done the trick in both cases. If you happen to find a bunch of cheap 2PDTs, it's nice way to use them up with marginally more effort than wiring a 3PDT for mechanical bypass; otherwise it is a good trick to have in your back pocket for fussy circuits that love 2 pop.
Anyway, hope this is as useful for someone else as it has been for me.
