Jovi Bon Kenobi
It's been awhile since doing these on the reg so I'm a bit rusty. Here I have my main board and relay bypass module soldered together via pin header. I added red and green circles in reference to the question below.
My question is, when connecting the pcb with attached relay board to in/out/DC...
1. Do I run two wires from each in/out jacks Tip lugs to their respective main board and relay board pads? Or just one wire to the relay board pads.
2. Same for the DC jack. Two + and - wires coming from the jack, one to red and one to green?
I just wanted to check so I can avoid trying to stuff two wires into pads or lugs if it's not necessary.
Thanks!
*EDIT* Regarding question 1, The pads in the red circles are for ground. Doy! Disregard question one, I figured it out. Whew, I am rusty. Still curious about question 2 though.
Thanks!
