Beatle Juice Fuzz
Cvp1969
I’m doing a Beatle Juice Fuzz build now- my initial test has nothing when the pedal is engaged. Then I discovered that I put a 22 ohm resistor at R3 instead of a 220k. I got it off the board and I realize Indont have any 220ks so I ordered a few.
Would that cause no sound in this case or will I have another problem?
Yep, definitely. R3 biases the input transistor.
You could temporarily tack two 100Ks in series just to see if the build works.
It won't be perfect, but it should be close enough until your resistors arrive.
Thanks.. and.. I don’t even have 100ks! I was trying to fanagle a way to do it with what I have and I just gave up!
