Ginsly
This is part of a larger project which was met with a resounding "dunno!" when I posted about it!
So it goes. I figured I would isolate the part I'm most curious about, since I'm trying to make sense of what's going on here. Might help me going forward.
The chunk below seems to be a Ge boost added before Q1 of a two-transistor fuzz. I could be wrong, but that's what it looks like.
On the back there is also a resistor leading from collector to power:
As far as I can tell, this is how it's set up (and yes, I accidentally marked the electro's negative leg toward Ground+). The transistor is a Ge MP40A, which likely (?) has an hFE around 40, give or take.
I've looked at several boost sections/circuits, and this one is just different enough that I'm not sure what to make of it, and why it was set up this way. It doesn't help that I don't know the exact values of each component! The B-C resistor is clearly 470K, and the collector-to-power biasing resistor on the back seems to be 47K. Then there's a resistor from base to ground, which may be 220K. It's very hard to make out the resistor and electro leading from emitter to ground.
So... what kind of "boost" would this be considered? In trying to figure out the values of the emitter resistor and cap, I haven't really found a similar setup that would even give me a starting point. The LPB is an excellent, simple boost, but it differs from this in many ways - it has two resistors from the base which form a voltage divider, where this only has one to ground. The LPB has a relatively small emitter resistor to ground, where this has a resistor and an electro to ground (could be anywhere from 1-220µF).
The designer says that the electro does nothing to the tone, but is simply there to reduce the footswitch pop. But wouldn't it act like a bypass cap in the position it's placed? Without the electro, the emitter resistor would seem to noticeably reduce the gain, depending on the value (which I can't see in the pic). I'm not sure why a cap would be placed in this specific spot in order to deal with switch pop.
I can certainly provide more info about the bigger picture here, but thought I'd start with the front-of-circuit boost since that's the nut I'm tryin to crack at the moment. This all seems very silly, but I'm kinda hung up on it for reasons unknown.
Any help in understanding what's going on here would be MUCH appreciated! I'd love to land on some possible values for the emitter's resistor and cap. Hell, maybe I'm wrong about some of the other ones too!
