I have just finished a duo phase, picture attached. The rate seems pretty fast, maybe slightly faster on one side than the other. Do the trimpots affect this? Or is there a mod that can be done to get a bit more range in the rate?
It's wired stereo at the moment and seems to be just two separate pedals period, only work if you plug into all jacks, for some reason I thought that if you plugged into one side you get to use both still? Or should I just rewire it in mono.
Also the switches don't seem to do anything, is this due to the way I have wired it?
