When I do the pots and switches I always place them on the PCB and then I carefully line it up with the box and then screw the pots and switches down hard before I solder the pots and switches.
You need to have the pots and switches mounted in the box before you solder them in, sometimes I put a small dab of solder on the middle pot leg to hold it in place while I mount it in the box and tighten them down. ( re-solder the middle leg first to take any strain out if you solder it first)
Usually it is enough to spread the legs a little bit so the pots hold themself in place though.
We do not want any strain on the solder joints when we assemble the box and that can easily happen if we solder the pots and switches in place on the PCB without mounting them in the box first.
If you are having a bad day already it can be a pain in the behind to align everything while trying to keep the pots sitting on the PCB when you try to mount the whole lot in the box though, I might have said bum and pubic hair and similar bad words when nothing wants to work.
I see you placed a connector on the DC power so it is easier to remove the PCB later on, I like that idea.
I have been using a Cliff DC 2.1mm external thread jack for a long time because I like being able to remove the PCB without de-soldering the power jack, I haven't used them on any C2CE projects yet but I might start doing it again.
Tayda has a clone of the Cliff jack but I get the Cliff ones from https://www.diyguitarpedals.com.au/shop/index.php?main_page=product_info&cPath=37&products_id=617
Love My Switches also has them as well as many others, https://lovemyswitches.com/cliff-sw...U359WqZ0yLWfLtTpgR7vyMztP6DMx2avWunmKdww7otAJ
Isn’t that just a standard fender style tone stack between the first valve stage and the HPF?My question is where could I place an EQ bypass in the schematic?
I just noticed that it looks like the 1/4" output seems wired in reverse, the signal is wired to the shield ring and the ground is wired to the tip on the socket.Forget the inside shot.
Here it is.
Nothing special. Used some RFT ECC82 tubes I found in an electrical store here in Germany.
Hi! Thanks for the comment. I understand what you're referring to, but I think it's not a bad idea to have the option. Note that C2C thought the same and added it to their latest assembled version or pedal for sale..Isn’t that just a standard fender style tone stack between the first valve stage and the HPF?
The most common way to bypass a fender tone stack is to lift the ground leg on the MID pot, the Nobelium has a resistor instead of a MID pot so just disconnect R21 2k7 ohm resistor and that should work.Hey guys... I already have my Nobleliumall wired and tested, it worked perfect the first time! I modified some things to make some aesthetic changes position to the cabinet, then I will publish photos...
My question is where could I place an EQ bypass in the schematic?I could go directly with a true bypass but I think the XLR would not work... ok my friends, I hope you can help me!
Thank you very much
Sorry if my English isn't good! I'm from Argentina.
I think what the new switches on that Nobelium that is for sale do is connect the 1/4" input directly to the 1/4" output, also the XLR transformer is connected directly to the 1/4" input socket.Hi! Thanks for the comment. I understand what you're referring to, but I think it's not a bad idea to have the option. Note that C2C thought the same and added it to their latest assembled version or pedal for sale... Thanks!
					pedalnetics.com
Tassie nailed it, those switches bypass the entire circuit, not just the tonestack.I think what the new switches on that Nobelium that is for sale do is connect the 1/4" input directly to the 1/4" output, also the XLR transformer is connected directly to the 1/4" input socket.
It is a way of bypassing all the electronics in the pedal itself, if you loose power to the pedal you can still get signal to both outputs, the 1/4" signal just goes in and out but the XLR still works through the transformer.
