The MOD Squad
Tassieviking
This Thread is for any and all mods that people want to share, I love modding circuits if I can make it more useful to me.
I especially like to add deep switches and Bass switches along with Bright switches so I can use the pedals for Bass and guitar.
I like to use the Tube calculators on the Ampbooks.com website, there is also lots of great info to read on their pages.
And I also use the online tone stack calculator a lot.
The first one I am going to screw with.....I mean show is the Ambassador tone stack, that is one weird adaptation of the Marshal or Bassman tone stack.
There is no Bass pot, the knob labeled Bass is in the position the Mid pot is normally in and the original Bass pot is just gone, shorted out.
This results in a tone stack with no bass control so what happens is you either boost the treble with the Treble pot or you cut the treble with the "Bass" (Mid) pot.
Try it here on the TSC : https://www.guitarscience.net/tsc/b...3=22n&RB_pot=LogA&RM_pot=Linear&RT_pot=Linear
I used a 1 ohm resistor for the bass pot but it should be 0 ohms, 1 ohm makes no difference to the TSC, to get a flat response you want the Treble pot on 0 and the "Bass" Mid pot on 10.
For Bass guitar I would use C9-220pF C10-220nF C14-220nF.
Increasing C10 and C14 increases the bottom end, reduces the tapering off of the Bass frequencies.
Increasing C9 brings the treble frequencies down, the frequencies of the tone control drops down where it changes.
Here is a bunch of pictures with different capacitors, read the picture title to see what the values are.
Cheers
Mick
EDIT: If you want to experiment then just place a SIP socket in place of the capacitors so you can change the capacitors easily.
The Next has to be the Ambassador circuit itself, if you want to use it for Bass I would make the following changes.
Cathode bypass capacitors C11 C12 C13 need to be 22uF but 47uF is ok as well if you play a 5 string.
Coupling capacitors C7 and C8 I would change to 47nF
Remove the bright caps C5 and C6, they are basically a variable High Pass filter that filter out Bass at low volume.
If you just want to use it for guitar and want a deeper tone then just increase C11 C12 C13 a little bit.
I would add extra capacitors across C11 C12 C13 with a switch so I can have Lead / Bass switching, I would also add a switch to switch out the Bright capacitors C5 and C6.
Schematic and other graphs :
  • Ambassador Bass Mods Schematic.pdf
The next mod I am going to show is more about what can be done to the BassDude, I think I only placed the Bright cap on a switch on my first BassDude.
When we look at the Bassdude it becomes obvious it is a copy of an earlier Bassman, the Bassman 5D6-A and the 5E6 both match the BassDude schematic.
The first thing that stands out to me is that we only have one input but the original had two inputs with a common Cathode resistor and capacitor,
since we are only supplying one triode we should really double the resistance of R16 to 1k6 and halve the capacitance of C8 to 120uF.
When I run the graph it does not make much difference if C8 went down to 47uF as far as I am concerned even for Bass.
( I still used a 820R resistor and a 220uF capacitor since it is not really much of a difference to us)
The next thing that really stands out to me and should be the first thing I noticed was that the Bassman used 12AY7 tubes in the preamp and not the 12AX7 the BassDude is supposed to have, that would be a lot less gain in the preamp and I have not even tried it yet.
THERE WILL BE A LARGE LOSS OF OUTPUT WITH LOWER GAIN TUBES I IMAGINE SO IT MIGHT BE TOO LOW WITH 12AY7 TUBES.
Then there is the obvious Bright capacitor C6 which I always place on a switch, the lower the volume the less bass you get with a bright cap so I always place them on a switch.
On the Bassman you have 2 channels and one has a bright cap for guitar and the other channel does not have a bright cap for Bass.
The coupling capacitor C5 is plenty big enough at 22nF for Bass guitar so I leave that alone in this one, 47nF will not hurt though.
I might leave the biggest mod for the next time.
  • Bassman-5E6-Schematic.pdf
  • Bassman-5D6-A-Schematic.pdf
This might be one mod on the BassDude that not many have thought of, change a few values on some components and add a second Bright cap on top of R12 and you have a Marshall JTM45 preamp, of course the JTM45 has 2 channels, one with and one without Bright caps so place both caps on a switch if you do this mod.
What do we need to do?
We could place a 68k resistor between the input jack and the PCB but I would not do that, the only real difference is that V2A does not have a cathode capacitor C9 and we need to add the 500pF Bright capacitor on top of R12.
R16-1k6, R17-820R, C8-100uF (120uF), C9-Leave Out, R12-Add a 500pF capacitor over the top, Tone Stack-please yourself with this one.
The more serious modder would also change the tone stack to a classic Marshall tone stack, we would just mount the pots in the box and then wire the resistor and the 3 capacitors to the pots themself and then run 3 wires to the PCB at the right places. ( C7 / C10 junction and R15 / Master junction and also a ground wire )
If you build a JTM45 BassDude then it might make sense to try some 12AY7 tubes in the real BassDude so they sound different, you might just need one 12AY7 and one 12AX7 in the BassDude but you just have to experiment with different tubes.
Bath Tub Reverb- SamuelG did a very nice mod to his Bath Tub pedal by adding a normal/deep/bass switch to his build.
All it involves is to add more capacitance to C2 to allow more deep frequencies through, he did this by installing C2 and leaving the legs long enough to add some wires to run to some capacitors,a DPDT ON-ON-ON switch and 2 resistors.
You will need the C2 capacitor 22nF 630V, another 22nF 630V capacitor and a 100nF 630V capacitor, and also 2 resistors about 2M ohm as well as a switch DPDT ON-ON-ON.
Here are the pictures which I have "borrowed" (nicked) from SamuelD's posts :
Borrow my pics as much as you like… since I stole the whole idea from you 😎
But I AM working on a Bathtub mod to use the ABE module! I’ll post if I get it to work.
Hi. I am getting ready to do the Bathtube reverb mod documented by @SamuelG and @Tassieviking and have what might be an elementary question. Does anyone know why the resistors in the path of the 250V line don’t need to rated higher in the same way the caps are? Is the current low, but voltage high? I am wondering if I need higher wattage rated resistors for the bass mod even though the other spots using resistors in the 250v path in the circuit don’t call for a certain wattage rating. I also have some spare 2.2M resistors and wonder if there will be much of a noticeable difference compared to 2M. Thanks in advance.
The resistors can be standard 1/4w resistors, they are not really needed but they help to bring up the voltage across the un-used caps so when you switch them in there is less chance of a pop noise.
They will charge the caps slowly so not much current goes through them so 1/4watt will be fine.
The resistors make no change in the tone so different values is fine, 500k to 2.5M
Thank you for the explanation @Tassieviking!
Oh, by the way, I'm in the middle of trying different values for my coupling capacitor. I'm still not happy with mine (the fc of the voicing switch is still too high). The capacitor C2 sees a total impedance of ~15k4. (The Plate output impedance of ~8k6, the following resistor network, and the 10k load impedance of the BTDR module all contribute to this value.)
So at this stage for a fc of 20Hz I'm looking at a C2 value of ~540nF.
I'll post some updates when I get to do some real testing.
Lately there has been some people wishing that the Space Heater would become available again at Sushi Box FX, the Space Heater is apparently just a Particle Accelerator without a tone stack.
You still need a 100nF 630V capacitor between V1 output and the Gain pot, and I imagine the output will be higher without the tone stack as well.
The way I would do it is to leave out C5 and C8, also leave out the Mid, Bass and Treble pots and then place a jumper on terminals 1-2 on the Treble pot to complete the circuit.
I would leave C7 and R10 in but experiment with the value of R10 so I get a similar strength signal to the Gain pot as when the tone stack is there.
If R10 is removed and replaced with a link we might have way too much signal going to the gain pot
And that is how we turn a Particle Accelerator into a Space Heater.
I will try one out in the future but I personally can't see any real benefit in removing the tone stack, but you never know till you try it.
Cheers
Mick
I think that reverb might get too muddy at very low frequencies (from what I have read), it will be interesting to see what you come up with.
I’m now working on applying the Fc switch to the wet signal but not the the dry path. Been busy lately so slow progress.
Okay so after three different itterations I'm finally happy.
To replace C2, I put in a 1uF 400V cap mounted on the underside. [Not acting as a HPF for the Dry path with an Fc of ~10Hz].
Then, to make a HPF switch for the Reverb Wet signal only, I cut Pin 3 short and mounted it via a 15nF cap. as you can see below.
Then Pin 3 is sent to a 2P3T switch which then adds two more caps in parallel. [Pin 4 is ground]
Up is C1 --> 15nF for Fc an of ~570Hz [Abbey Road standard for Reverb]
Middle is C1 + C2 --> 15+10nF for an Fc of ~340Hz [Modern mixing standard for Reverb]
Down is C1 + C2 + C3 --> 15+10+22nF for an Fc of ~180Hz [Warmer for Bass Friendly Reverb]
I can use 63V caps because the C2 cap isolates the high plate voltage.
All leads I've changed to shielded cable, as you can see below. [The Blue cap is C2 at 1uF .]
I'll get back with a sample video when I get a chance, but I'm much happier.
This mod keeps the dry signal of the instrument completely tooby beautiful but allows me to remove the mud from the Wet Reverb without loosing my bottom end in the Dry :)
Oh, a C2 of 0.68uF also works and will give an Fc of ~15Hz but I didn't have one on hand.
It sounds like you got it working really good Samuel, is there any reason to have C2 so high ?
I would have thought a cap to filter anything below 30Hz would be ok since a 5 string is needed to go that low, what value would you need for C2 to equal 30Hz or even 40Hz ?
Also, could you draw up the circuit of what you did with leg 3 of the BTDR2 module and the switch ?
I think your mod will be one I will try on my next Bathtub Reverb pedal for sure.
Thanks
Mick
Two reasons for the high C2. The main one being, that's what I had on hand :) The second is that I tend to let pedals have a specific role (I deal with mud with my SA EQ2), this way I don't have multiple pedals contributing to a HPF.
C2 sees a combined effective impedance of ~15.5k. So, for an Fc of:
20Hz - 0.51uF ~0.47uF (21.9Hz actual)
30Hz - 0.34uF ~0.33uF (31.25Hz actual)
40Hz - 0.26uF ~0.22uF (46.8Hz actual)
As a first order filter, the Roll-off rate is -6dB per octave below the fc.
When I next order parts I'll add some High Volt 0.47 & 0.33uF's
I'll draw up a circuit when I get a moment :)
