The Orange Squeezer is a half-wave rectifier (the diode splits the signal in two), feed-back design.
Some people do love the Orange Squeezer on bass, but stock it does actually cut some low end (which can be a good thing if your signal is a swampy mudbog).
I'd play with C1, the stock input is 47n, and increase it to 56n and keep increasing it, 68n, 82n up to 100n maybe 120n or even 220n until I find the Goldilocks' cap.
However, IIRC the circuit clips the initial transient which is exasperated by hitting it with more gain which is what bass freqs have and do, gain up and muddy things up. The transient will briefly clip before the compression kicks in, so the OS has a naturally higher noise floor and grit to it.
John "Midway Fair" Patton uses a NE5532 for the op-amp instead of the 4558, and says it's a little quieter which may help mitigate an increased input-cap's distorting things down the line. Try Patton's NE5532, but also try TL072, Burr Brown, TI RC4559, TLC2272. Having said that, some people still prefer the 4558.
Further Noise-Reduction:
JFETS 2N5457: Use quality Fairchild (try BF245B, 2N5458, MPF102). The MPF102/J113 may be better for bass (slightly less gain).
TANTALUM and/or XICON caps
DIODES: find the right Fv diode, 0.25–0.35 : 1N100 is unobtanium, so find a Schottky diode with the correct Fv — Schottky 1N5817; flaunt 'm if you got'm VD1210-Ge,
 1n40 Ge, 1N34A... 1N60P Schottky work-a-like of the 1N60 Ge... Russian D9 types... BAT4x ...1N4148...
Next up, I'd play with C4 (also 47n, stock), since it's directly inputting signal to the op-amp I'd be even more careful and lean towards increasing it less than the input cap. For this one I'm just stabbing away in the dark hoping I hit the right target.
Here's the BASSification suggestions from DIY Doyen Mark Hammer and A Colman:
1)    Change output cap from 4.7µF to 1µF — [YES! Counter-intuitive, I know, but I forget the explanation why]
2)    Change bleed-cap from 4.7µf to 10µF. [cap connected to the diode, in this case C8]
3)    Decrease feedback resistor from 220k to 200k. [R10, should help reduce distortion]
MORE BASSIFICATION:
More fiddling with CAPs:
Add 51p parallel with R10
Add 100p across pins 1 and 3 of output pot
FURTHER READING:
https://www.diystompboxes.com/smfforum/index.php?topic=105710.0 VERY GOOD BIAS SETTING INFO HERE!
RG KEEN::
https://www.diystompboxes.com/smfforum/index.php?topic=54308.0
The Technology of the Orange Squeezer
Copyright 2007 R.G. Keen
Oh, there is one more thing: the transistors do NOT need to be matched.
