Unison Double Tracker with Stereo Mod
Magous
5.00 star(s)
Unison Double Tracker with the Stereo Mod in matte black. Sounds amazing, probably my favorite build to date. Used the pin 1 tl072 mod to make it stereo, except, I went through the front and jammed the lead of the cap into the socket the same time as the tl072. No soldering, works great. Used a 4pdt so that the bypass is also stereo, and the ring and tip both have a bypass signal. Highly recommend this build, especially if you play with a dual amp setup.
Nice build and implementation of the stereo mod. Great artwork
This is the one that I will try to replace my mimiq with someday.
Looks great, that's awesome. The unison double tracker is on my radar
Thank youu. I definitely recommend it. I’m using it as an always on at the semi-beginning of guitar signal with parallel ODs out to two amps. It adds a thickness I may never be able to play without again 😂
Hello
Can you please share the stereo mod
Thanks
Rob
Follow this thread: Unison Stereo Mod
Only two I things I did that weren’t in that thread were 1) instead of soldering into pin 1 on the back, or directly at all, I just jammed the lead into the 8-pin socket the same time as the tl072 without soldering at all. 2) used a 4pdt, instead of a 3pdt, wired the first 3 poles normally like the wiring diagram, and for the forth pole had a the center going out to the stereo jack — the two other spots on the pole were a passively split bypass signal and the stereo mod going into the other, switching between the two to the fourth pole output.
Let me know if that doesn’t make sense the way I typed it lol
