Unison Double Tracker with Stereo Mod
Magous
5.00 star(s)
Unison Double Tracker with the Stereo Mod in matte black. Sounds amazing, probably my favorite build to date. Used the pin 1 tl072 mod to make it stereo, except, I went through the front and jammed the lead of the cap into the socket the same time as the tl072. No soldering, works great. Used a 4pdt so that the bypass is also stereo, and the ring and tip both have a bypass signal. Highly recommend this build, especially if you play with a dual amp setup.
Nice build and implementation of the stereo mod. Great artwork
This is the one that I will try to replace my mimiq with someday.
Looks great, that's awesome. The unison double tracker is on my radar
Thank youu. I definitely recommend it. I’m using it as an always on at the semi-beginning of guitar signal with parallel ODs out to two amps. It adds a thickness I may never be able to play without again 😂
