falco_femoralis
I made one of these in the past in a horizontal format but I wanted to make a normal one too. Here's how we started
I took off the bottom two pots as I wanted to change the setup. This board also has a random 18k LED resistor so I pulled that out as well in exchange for a 4.7k
All the wires are run and the PCB is in the enclosure. I installed the bottom pots such that their legs were at weird angles. The easiest way to get everything together was to put the pots loosely in the enclosure and then mate up the PCB to them. After everything was tightened, I soldered them in
Audio and DC jacks are in
I'm installing the footswitch along with a new thing - a trim pot to be able to adjust the brightness of the LED. I trim the wires to length, strip and tin the ends, then feed them up with needlenose
Bent the legs of the LED to get it in place and we're all done
And the front
I love the Lunar Module, such a great fuzz.
And the front
