DGWVI
- Build Rating
- 5.00 star(s)
Only tweaks to this are the opto- I used a VTL5C1 for a much wider dynamic range than the LCR0203 called for. I also replaced R17 and 18 with a trimpot to better balance the wet signal, as stock it's quite a bit lower than the dry signal
I love this circuit, and this is the third one I've built, and so far my favorite version. The 5C1 definitely opens it up quite a bit more.
If you're a fan of touch sensitive effects, and have a thing for ring mods, bit crushers, and/ or temolos, I say you should definitely give this a go. It's a super simple build beyond boxing, and it's quite a lot of fun to mess with. DeadEnds boards are top notch, if maybe just a tad oversized
