DEMO Troglodyte — Self Oscillating Reverb
Aleph Null
Troglodyte is a versatile reverb capable of everything from short, bright, roomy reverbs, to dark, cavernous, infinite sustain, to full-on self oscillation. I built Mad Bean's Moodring with a short brick and loved how that could go from short and bright to full-on runaway oscillation. I set out to make my own design with all the features from other reverbs that I loved, plus something that could do precise, controllable self oscillation and reverb swells.
The enclosure is a limited run from Love My Switches.
The Belton Brick is a big boy! It's soldered in place on top of the board so that it hangs over the bypass LED and leaves just enough room for the footswitches. I made sure to leave plenty of room for top mount jacks and to get a soldering iron in to the potentiometer lugs once the rest of the board was populated.
An input buffer feeds a PT2399 delay chip. This provides pre-delay of up to 300ms or so by way of the Onset control. I used pretty standard filtering on the delay input. The output stage of the delay does double duty as additional filtering as well as a gain stage to feed clipping diodes for the Saturation control. The saturated signal then hits the Belton Brick. One of the Belton 3's outputs feeds a tilt EQ centered around 1kHz and goes to the output mixer. There's enough gain on tap that you can get the wet signal well above unity with higher Saturation settings.
I wanted a "kill dry" option, but I didn't want to stop there, so I went for a Dry mix instead. This goes all the way from "kill dry" to "solo boost" with 14dB of gain available. This means I could set the unit for a boost to take a reverb drenched solo, or I could set it to cut volume for an ambient verse. I like having options!
The Sway control is the same envelope-controlled vibrato I used in my Tape Delay.
The crowning feature of this reverb, in my opinion, is the Feedback and Swell|Delay controls. The Feedback sends the second reverb ouptut back to the delay input allowing for momentary gushes of reverb, infinite sustain, or self oscillation. The feedback loop interacts with the other controls to create some surprising results. The Swell|Delay switch controls how the momentary foot switch interacts with the Feedback control. In Damp mode, the Feedback control is connected by default and is disconnected when the foot switch is pressed, dampening the feedback. In Swell mode, the Feedback control is disconnected by default and only engaged if the foot switch is pressed, allowing the reverb to swell in.
Here's a demo:
As always, I have extra PCBs; if anyone is interested, just DM me.
Do you have any ideas for a Fallout related theme? 😉
There's not enough room 😜
I kid. I think I sketched something out at one point, but it was for full UV. I'll have to come up with something else to work as (basically) one color to contrast with the aluminum.
Mods! Are you kidding me! It's already got 8 knobs and three switches! What could you possibly add?
Actually, I just built it as-is and never felt the need to tweak anything. Nice work!
You mean you didn't do the "robot cutting wet farts in an empty airplane hangar" mod I mentioned in the build doc?! 😜 I designed it to do everything I wanted in a reverb, but that doesn't mean it'll satisfy everyone. I'm glad to hear it's working for you!
Wow! this is amazing. I built a Mood Ring once and loved it, but this.. Are there any PCB left or future plans to make more?
Q: What does the trimming procedure for T1 looks like?
Q: What size of enclosure is that?
Going through the schematics I found that the labels for RV3 (Saturation) and RV5 (Feedback) were missing.
Anyway, I'm looking forward to build this one.
T1 is a Bourns 3362. It sets the minimum amount of resistance in the feedback loop. The default setting is halfway. If the feedback control is too touchy, adjust the trimmer up for more resistance. If you need more feedback, adjust the trimmer down for less.
The enclosure is a 1590BB.
I'll have to update the build doc schematic. Thanks for letting me know!
P.S. If you work up a vero layout or something, I'd love to see it!
