rozencratz
Hi All,
I've read all the forum answers on this and have still hit a roadblock. LED 1 and LED 2 stay on regardless if the effects are on and I can't figure out why. I have confirmed that the switch is not the issue. The switch LED comes on and off as appropriate, the effect turns on and off as expected too. I tested continuity on the switch and confirm the circuit is open at the center middle and center top lugs when the switch is on bypass and closed when engaged. The LEDs are otherwise functioning as expected with all potentiometer adjustments and I can use the pedal. But those LEDs are just permanently on.
I've checked and cleaned every solder joint and nothing changes.
I tried looking at the schematic to figure out where a potential accidental ground could be for both LED 1 and 2 and still can't find anything.
You'll see I haven't even soldered in LED 1 yet so I really don't get how that can also have a bad ground somewhere
Would appreciate any insight.
