Drill Press is assembled. Need to spend some time this weekend getting the pillar gear aligned and stuff. Probably also should:
- Bolt it down
- Build an extension table with:
- Replaceable MDF sacrificial center inserts
- T-track for hold-downs
- A fence
- Modify a Rubbermaid bin or something like that to act as a swarf collector that can slide under the table
Seems pretty decent so far, 12am, so I can’t really run it right now to test the runout, but it seems solid. The table crank seems *slightly* less sturdy than I’d like. The table itself is rock solid, but it has some wobble when cranking up and down, meaning it wouldn’t be ideal to use the crank as a way of getting more stroke depth than the 2” quill travel allows for. The 2” stroke is really the only downside I see, but upgrading to a 12” drill press with a deeper stroke and better table mechanism would be almost 3x the price I paid for this, and I think it would be a bit too big for this workspace. 2” of quill depth shouldn’t be an issue anyway for pedal stuff where everything is 1/8” thick at most— only thing I’d use this for where I need more depth than 2” is when I’m drilling pen blanks, but I can do that on the floor drill press in the garage anyway since now I’ll be able to keep that one permanently at the right speed for drilling hardwoods like that.
