Positive Ground Circuit Redesign??
When we say clock it's a bit of a generalisation as there's several components to it... a modulation element, an oscillator and usually, a flip flop to provide both phases i.e. the tick and tock of a clock.
The square wave 'clock' directly connecting to the BBD isn't what changes the sound, assuming it's nice and clean, it always just puts out a square wave to tell the BBD at what speed to pass its buckets.
In this case the 4007 is configured as a simple two inverter oscillator with the timing resistor being varied by an LDR to modulate it and the 4049 is inverting its output to provide both the necessary phases.
If you look at the MN3102 datasheet, an example oscillation circuit is given, it's the same oscillator as here, just a bit meatier followed by a flip flop and some waveshaping.
It's how it's modulated that's important... although some chips are beefier than others which can impact sweep range and a flip flop is going to give a cleaner square than something simple like this configuration and the MN series has said built in wave forming business which offers some benefits yada-yada caveats.
In the CE-2, the oscillators timing is modulated by an astable formed with the transistor, in the small clone a diode's used a dirty variable resistor in an A/DA flanger the CD4007 is just using a MOSFET from inside the chip as a much better variable resistor to modulate the CD4047's oscillator but all these methods of modulation have their own linearities and such which does start to impact the sound of the modulation.
Here, you have an LDR as your modulation element, as long as that LED/LDR pair are providing the same sweep range on whatever oscillator you plonk them on to vary, you'll get the same the result out, only you're going to add a flip flop for a nice clean square wave so the BBD is happier.
Put another way, if you added the wave forming from the MN310X series to a CD4047 with some additional circuitry and were getting the exact same square wave timing there'd be no audible difference between them in a DM-2.
Edit: But yes, quality of the clock does have some impact, although if you're talking about the difference between a flip flop output and one with waveforming the benefit is getting smaller, if you're talking about one with sloppy edges, you'll start to hear it in poor performance from the BBD.
That's a bummer. In that case, would two 3009s be a better choice?
Depending on the clock frequencies required, an MN3007 might be fine?
The SSI isn't a bad chip as such, it's just not the circuit I'd pick to drop it in, in an ideal world we'd have access to MN3004 but beggars can't be choosers in this day and age; kind of an irritating circuit in general to make subs in but we'll make it work.
By replacing the source follower resistor (bbd output resistor) with a current sink it'll hopefull give the SSI a slight edge in S/N to pick up some slack... headroom still isn't huge but should be fine for single coils once the circuit gains have been fiddled with.
Got it, thank you for the detailed explaination.
Do you think the LDR tracks with the LFO linearly or there is some shaping that would need to be considered to get the same sweep character?
No, LDR's aren't linear in response but I'd be more concerned with finding one with a good resistance range to get a decent sweep ratio over that sort of nuance... LDR's age, an original unit isn't going to give the same response it did when new either.
Oh and no need to bother with the original zener based regulator, it'll give a hair under 6V out, just lift the ground pin on a 78L05 with a pair of 1N5817 or 1N4148 if you want a tiny bit more sweep, should be close enough.
Just use an LM1458 for the LFO rather than bothering with individual 741 too, not the 70's any more, we can afford the extra few pence.
Will do. I was planning a dual upgrade, as well. :cool:
Right, so, quickly tossed this together, I've shifted the mixing trim to the BBD input to account for the new chips lack of headroom and the insertion loss difference between the two chips.
It's not an ideal solution as it messes with the bass response a bit... but I couldn't think of a better way of doing it without recalculating everything or adding another op-amp and besides, the original mixing trim messed with the frequency response any way so we'll call it a draw.
You can always reduce C3 a bit if necessary.
The wet mix is now a fixed 13k, the only gut shot I could find had the 22k trim set dead centre so 2K2+11k, close enough but feel free to diddle.
Never used an SSI2100, don't know its idiosyncrasies so I'd definitely breadboard first but hopefully it'll work.
If it sounds crap, we'll have another look at it or go for a different chip.
... it messes with the bass response a bit... ... close enough but feel free to diddle.
Singing, hey diddle diddle
With the trimmer in the middle
Of the wet-mix like you didn't care
Okay, but "it messes with the bass response" in a good way or a bad way? Asking on behalf of a bass-player I know...
Also... Thanks for your circuit spelunking.
It just lessens the response of the 220n/10k hi-pass a bit, so you get more bass passing through.
Good for bass players? Some seem to prefer less bass on the wet side; solved by reducing C3's value.
Thanks for taking a look! I'd be worried about heterodyning with a charge pump. LectricFX used charge pumps in a lot of their early versions of flangers and have since updated them to 18V. There were tons of troubleshooting threads back in the day on Mad Bean :)
The LT1054 seems to have become favoured more recently for this and has a high clock and doesn't seem to have the heterodyning issue.
