Spark_Trooper84
I have just completed building the Protoboard.
Overall, the build was smooth enough, and i'm confident i do not have any solder bridges.
I socketed the TC1044SCPA IC, just to prevent the possibility of overheating the IC during soldering.
I sourced all the correct parts per the build documentation from Mouser and Tayda with no substitutions except the called for 100n (.1 uf) Film Capacitor.
I used a 100nf MLCC cap for that, but thats on the power circuit so i doubt that it's going to pose a problem.
If i'm wrong in that assumption, please correct me.
I'm using a D'Addario 9v power supply to power the board.
To test my work, I have powered the board and probed the head pins for voltages.
I'm getting some variations off of the specified voltages i expect to see from this probing, and want a sanity check.
The Multimeter I'm using is not the greatest, it's a cheap Commercial Electric branded unit I picked up from Home Depot.
With the probes shorted, the unit reads .03v
Setting the voltage probe to 20v, I get the following readings
3.3v header - 4.3v
REF header - 5.5v
5v header - 6.1--6.3v
9v header - 10.7-10.8v
-9v header - -10.0v
18v header - 20v
With these all measuring above the specified voltages, is this something i should be concerned with?
Is something wrong?
Thanks for any help.
3.3v header - 4.3v
REF header - 5.5v
-9v header - -10.0v
18v header - 20v
Is something wrong?
