Adding a transistor selector switch to a RangeFinder
BJG
I want to mod my rangefinder by adding a switch (or array) to go between different transistors. Is there a best-practice method for wiring something like this up? I was hoping a 3pdt on/on would work, but I'm also super new to this.
Thanks!
It can be done, but can I ask why?
Not sure you'll gain a ton vs the biasing issues you may have. I.e., the bias setting that's best for one transistor may not match the next. For Si, this is much less of a problem but for Ge, it could be a big issue.
If you find 2 germs that sound good without rebiasing, then yeah, a 3pdt will work.
You can usually get by with 2 poles, but it's probably not worth the effort in this circuit/easier to just mount them to the switch.
Get a switch with lugs, not pc pins, and wrap the legs through it for an easier time soldering. Match C, B, and E on each side and to the PCB.
I have an OC76 and a CV7007 that bias out within .1V of each other when swapped and I can't decide which one I prefer so I figured why not both. Ive been swapping them back and forth for a while and decided I like both and they feel different enough to have in one circuit. The OC76 has a little less low end and more aggression while the CV7007 feels a little thicker/smoother.
You can order a PCB for transistor swapping:
MOONN WHYNOTBOTH? 2 transistors
MOONN WHYNOTMORE? 4 transistors
There used to be a few other places offering such a PCB, but I can't remember who and can't find the answer in my notes.
It's not hard to wire it up yourself, though...
More than likely, you'll want to use the 3PDT method:
When there's a common-leg, you can get away with a DPDT
Here's a 3-transistor Rotary option, in case you find yet one more transistor you like:
or
If you need to adjust the bias...
Lastly here's a Cornish thing that may inspire some extrapolation...
CORNISH-PLUSH TREBLE BOOSTER VERO w: transistor swap.png
Final Update:
I did a bracket style competition with the Ge transistors I had and originally landed on the CV7007 as my classic Rangemaster sound with a low gain MP39B as option two. I was about to wrap it up when I decided to throw a silicon PNP in there.
All the germaniums sounded like different versions of a Rangemaster while the silicon made it sound like a completely different pedal. There was a little high-gain buzz at first and the bias was high so I had to add some resistors to clean it up and it sounds great now. The silicon has a totally different EQ curve and gain characteristics than the CV7007.
I'm still new to super new to this, but I think I correctly diagramed out what I landed on. Before I box it up, I need to decide if I want the option on a toggle switch or another foot switch. I'm loving how many different sounds I can get with the capacitor array and transistor switch.
Keep in mind @BJG that with you switch as is, the BIAS control will only be useful when the selector switch is engaged one way. Not sure if you want to incorporate that or not into both transistors.
You could always include bias resistor(s) in the switched transistor sub-network. The switched resistors could be all or only part of the total bias resistance, but are enough that both transistors are optimally biased.
(I could be totally wrong in my explanation here, so keep that in mind)
The Ge transistor is biased to 6.75V (trim is maxed out, so I can't get to the recommended 7V). When I first auditioned the Si transistor the voltage jumped to just under 8V. I originally put a 100k pot to ground off the Si transistor to bias it, but found that the pot on full brought me to 6.95V, so I just replaced it with a fixed resistor. When I put together the Si circuit on strip-board, I could add a trim in case I replace the transistor in the future and need to re-bias.
Final build photos. I swapped the 22k resistor for a trim pot so I could dial in the gain better.
