I have an OC76 and a CV7007 that bias out within .1V of each other when swapped and I can't decide which one I prefer so I figured why not both. Ive been swapping them back and forth for a while and decided I like both and they feel different enough to have in one circuit. The OC76 has a little less low end and more aggression while the CV7007 feels a little thicker/smoother.It can be done, but can I ask why?
Not sure you'll gain a ton vs the biasing issues you may have. I.e., the bias setting that's best for one transistor may not match the next. For Si, this is much less of a problem but for Ge, it could be a big issue.
If you find 2 germs that sound good without rebiasing, then yeah, a 3pdt will work.
You can usually get by with 2 poles, but it's probably not worth the effort in this circuit/easier to just mount them to the switch.
Get a switch with lugs, not pc pins, and wrap the legs through it for an easier time soldering. Match C, B, and E on each side and to the PCB.
Could someone do a diagram for dummies?
I'm building a Trumpeter fuzz and would like to have a dpdt for Q2 Silicon/ GE.
Also should I use B50k or C50k for the Bore and Mood??
Thanks!
@Feral Feline
