Cetus- Zener diode substitution
Synchrony Pedalworks
I have a huge packet of zener diodes, but I failed to look and see if I have 2V7 diodes. Unfortunately, my pack doesn't have that value. In the Cetus, the 2V7 diodes are used in series with another valued Zener diode. I believe that they are being used as clippers. One is paired with a 3V6 and the other paired with 5V1. From what I briefly searched, it may be possible to use different values that add to a similar value of the sum of the original two diodes. The only difference is the forward voltage of the forward facing diode does enter the equation.
If I changed the value of the two diodes to equal the sum of the original schematic, would it alter the pedal significantly?
I may test the idea with the breadboard, but wanted to see if anyone had any other thoughts?
Solution
You can use multiple diodes (zener or otherwise) that add up to the required voltage tacked across the pair as long as:
1) You use a separate string of diodes for each polarity
2) At least one of the diodes in each series string must be non-zener (silicon, schottky, as long as it doesn't break down in reverse like a zener)
Or you can use the closest thing you have.... or I could just send you a couple 2.7V zeners....
Solution
That is great info and offer. I have a ton of zener diodes, and enough options to add up to the required voltages. I can make this work. This info gets me going and helps a lot. Thanks!
