Erik S
I like your wood fence idea - will have to look into that.
@HamishR did a nice write up of his fence method here:
Since I got my drill press drilling enclosures is easy. As I have mentioned before I use a short straight piece of timber as a fence, so the I only have one direction to get the hole wrong in.
Say you have an enclosure you want to drill for a four-knob circuit. Two at the top, two an inch lower, as is common with many PCBs. I put some masking tape on the enclosure where I want to drill the holes and mark them using a rule and a set square. I'll mark the distances with the rule and use the set square to draw a line. I use the lid of the enclosure, hold it against the side of the enclosure...
Here's another interesting idea from that thread
Another thread
https://forum.pedalpcb.com/threads/drilling-raggedy-holes-for-top-jacks-is-there-a-better-way.21814/
And another...
