SOLVED Aion Draco (Dr Boogie) JFET Bias
faramir
Built an Aion Draco Dr Boogie clone. Only issue I ran into was biasing the 4th J201. I could only get it to 5.8v with the trimmer turned all the way up. The others all could easily get 4.5v. Any ideas on why this might be? My guess is a bad J201, possibly damaged by me during install? I used a soldering iron at 700 deg F and they are SMD's installed straight to the board by me. I got them from Stomp Box Parts. Not sure how easy they are to damage or how they would behave if I did.
Despite this it actually sounds pretty good though its a bit staticky-fizzy sounding at some settings. Hoping fixing that bias issue will help. Definitely sounds better at 18V (I did the bias at 9).
Since I haven't diagnosed the very low output problem with my Boogie Monster yet, I decided to build up an etched pcb version that I created a couple of years ago and it works properly. I'm still going to try to get my Pedalpcb version working by using a tone generator and a scope to find out where it's losing 99% of its output level.
Following up on this. I replaced the JFET and it biases easily now. Doesn't sound much different. I think my room is just really electrically noisy and its a high gain pedal.
