Moonshot tremolo volume drop
Peors62
Hi! This question has been discussed before but i would love to get some more specific guidance if possible!
Put together a moonshot and it works fine, but when activated there’s a significant volume drop and it’s quite unbearable.
What would be the best solution to this? Someone suggesting raising the value of R3 to around 330k from 220k (if I remember correctly), or to raise volume pot from B10k to a higher value, if so to what value?
If any of you have any input on replacements for these values and what would work best, I’d love to hear it!
hmmm, weird..
Just double checked all values on all components and everything checks out.
Resistors look good.
I haven't built the moonshot, but on the Sproing Deluxe I found out there's a huge volume difference depending on how much light from the LED is hitting the LDR. The way you orient the parts has a big effect on that.
Here's an example courtesy of @VanWhy of a more aggressive orientation.
Now that you mention it, i did think about this the other week, had completely forgotten. I’ll try and cover it with something, hopefully it’ll dampen the light from the led. Thanks!!!
Just to be clear - I'm suggesting you experiment with getting more light to hit your LDR.
The easiest way to do that is to point the light-sensing side of the LDR towards the LED. If you leave the leads long-ish you can have some adjustability in how you set the gap.
Ohh sorry not dampen lol, was multitasking while I wrote that. but i tried to bunch them up together a little more and it seems to work quite well!! Will have to experiment a little but this seems to be the solution!!
Thank you so much!!
