UtilityBeltFX
Here she's is, all bolted together, wired and strung up! I'm very, very happy with how it turned out, although I won't be able to plug it in until tomorrow. The one piece body is very resonant and the satin mahogany neck feels fast and full.
A couple things right off the bat:
1) I immediately ordered a replacement Hipshot hardtail in the .175 height. I don't understand why Warmoth sells the .125 version but with the saddles maxed out I'm barely escaping fret buzz as is. So that will be changed shortly.
2) This is my first time building a telecaster and I learned a ton, especially regarding installing the control plate and output jack. Highly recommend having all controls installed before drilling mounting holes for those so you know there's room. I half-assed the control plate (switch only, no pots) and now there's an extra set of holes underneath. But you will never see those thankfully.
3) This needs a setup badly. There's a high fret at the 15th (Musikraft neck) so the 14th are dead notes on the ebg strings. The frets also feel quite rough but I'll hit those with some steel wool and Dremel when swapping the bridge soon.
