DEMO Optical Weeble
Aleph Null
I was happy with the sound of the original Weeble, but I quickly grew frustrated with the low headroom.
I had originally intended on housing the new version in the old enclosure, but I couldn't get the rate LED to work in a satisfactory way, at least without too many additional parts. The upshot is that I can use my standard bypass board.
The Weeble started as my take on Tim Escobedo's Wobbletron and added a second phase stage for more depth and dimensionality. In this version I swapped the JFETs for LDRs, which meant I needed to change some of the values in the phase stages as well. I also increased the range of the Rate control stightly. The depth is good at 9v and better at 18v. The sweep is much smoother with LDRs. The capacitors in the all-pass stages really do make a difference in the tone of the effect. The Throb and Chop switches allow the capacitor in each stage to be selected. Because the phasing and vibrato effect are frequency dependent, the perceived depth can change depending on the guitar, pickup selection, or where you are playing on the neck. The voicing options allow you to dial that in.
I'm pleased with this verison. I find phase vibrato to be much more nuanced and interesting than delay based implementations.
Here's a demo:
As always, I have extra PCBs. If you'd like one, DM me.
Really enjoying the weeble saga! This one sounds noticeably smoother but still seems to have the character of the previous iteration. And these dipped enclosures rule.
The JFET version is definitely more lumpy.
Very nice! And that enclosure looks awesome!
Hydrodip has to be the best bang for buck when it comes to enclosure finishing!
I just noticed that you laid the LDRs flat instead of pointing them at the LED. Did you try both ways? I guess you preferred them flat?
I didn't try both ways. I did put HVAC tape on the enclosure lid to reflect the light back on the LDRs. You might be able to get a little more depth by pointing the LDRs at the LED.
