Good question!What's the input to the one OTA at R14 doing? Why doesn't that go to the other one?
I had to look up what a linearizing diode is, and I'm still not sure I fully understand it though I really appreciate the explanation -- IIUC these diodes are matched with the input transistors of the OTA to cancel out these transistors' non-linearity at low input signal levels? When I looked it up I ran into this discussion which was interesting. Is there a reason you chose LM13700 over the SSI2164, which doesn't appear to need external connection for biasing? (Or is the "MODE" pin of the SSI2164 basically the linearizing diodes?)Good question!
R14 biases the linearizing diodes on U2C. Since U2A's and U2C's inputs are wired in parallel (pin 4 to 13, pin 3 to 14), the two OTAs can share one set of linearizing diodes. If we look inside the OTA, we can see that the linearizing diodes (D2 & D3) are connected to the input pins.
I don't know, maybe. Haven't tried it. The thing I like about this circuit is its fast attack. Increasing R21 reduces the compression, so that might be a better place to start.The peak detection circuit and decay have already been discussed. But would a variable resistor in place of R9 allow for some useful "attack" control?
I'm starting to work on a layout.
